I am new to the F5 BIG IP LTM and have been asked to have it display a "maintenance" splash screen when all of the pools member servers are down. This seems as though it is easy enough and I have found several examples on how to do this. I am trying to follow the directions on this page : [link text](https://devcentral.f5.com/wiki/irules.ltmmaintenancepage.ashx/) My issue is that when it says "copy the file" or "upload the image", I do not know how to do that in a Linux based interface. I am trying to learn, but it is not fast enough for the results expected of me ( I am a Windows Sys Admin ). Are there any "dumbed-down" instructions for someone just learning Linux. Thanks.
Sorry, I do not know why my original post did not wrap the text. Reposting : I am new to the F5 BIG-IP LTM and have been asked to have it display a “maintenance” splash screen when all of the pools member servers are down. This seems as though it is easy enough and I have found several examples on how to do this. I am trying to follow the directions on this page : [link text](F5 Cloud Docs) My issue is that when it says “copy the file” or “upload the image”, I do not know how to do that in a Linux based interface. I am trying to learn, but it is not fast enough for the results expected of me ( I am a Windows Sys Admin ). Are there any “dumbed-down” instructions for someone just learning Linux. Thanks.
Hello,
This devcentral article is quite old. You have new options now. here is a little example :
when CLIENT_ACCEPTED {
set default_pool [LB::server pool]
display maintenance page if no pool members are available
if { [active_members $default_pool] < 1 } {
HTTP::respond 200 content [ifile get "/Common/maintenance.html"] noserver "Content-Type" "text/html" "Cache-Control" "no-cache, must-revalidate"
how to offload backend server error messages
when HTTP_RESPONSE {
if {([HTTP::status] starts_with "404") } {
if { !([class match $method equals "http_method"]) } {
HTTP::respond 404 content [ifile get "/Common/404.html"] noserver "Content-Type" "text/html" "Cache-Control" "no-cache, must-revalidate"
display maintenance page when load balancing fail
when LB_FAILED {
You just have to upload your maintenance page as an ifile. here the link to ifile description : 404 Page not found | BIG-IP Documentation
Hello,
when LB_FAILED {
Thanks so much!!! This looks like something I can handle. Let me give it a try.
Yann, this worked wonderfully. I could not get it to use the [ifile get “/Common/filename.html”] so I went the ugly way and embedded the image I had as Base64 and that worked. Thanks.
