Hello Devcentral,
How i can parse a string in order to obtain only the ten last characters and save them to a variable ?
Thanks in advance,
Best Regards,
M.
Hello Devcentral,
Thanks in advance,
Best Regards,
M.
something like this may work for you.
set lastTen [string range [expr [string length ] - 10] end]
I believe range uses index 0, so I updated it to length minus 10.
