Hi, Is there anyone who can help me with the following problem?
My internal server is configured to access a URL: https://sample.domain.com/soap/ There is no possibility to change the above URL in the server (that would be to easy).
The supplier is changing the URL to https://sample.domain.com/soap/test/ I want to rewrite the URL in my F5 LTM through a VIP. Can anyone help me with a example iRule to do the trick? Greetings Peter
The replacement to HTTP Class profile in 11.4.x is the local traffic policy. See Local Traffic - Policies - Policy List. Assign this to the VS as you would’ve done for a http class profile.
To make configuration simple, you need to force your server to resolve the hostname to the IP address of a VIP on the bigIP.
To change the URI, you can have the VIP iRule change that before your forward out. If the server does not respond to redirects like a browser: when HTTP_REQUEST { if { [HTTP::uri] equals “/soap” } { HTTP::uri “/soap/test” } }
If the server DOES respond to redirects you can do this:
if { [HTTP::uri] equals "/soap" } {
HTTP::redirect "https://[HTTP::header host]/soap/test"
Hope this helps. You may want to re phrase you question and include more details in case my reply does not answer it for you.
section from reply above. To change the URI, you can have the VIP iRule change that before your forward out. If the server does not respond to redirects like a browser:
HTTP::uri "/soap/test"
