HTTP to HTTPS without redirection
Hi Experts ,
I have a requirement where CLIENT makes a HTTP_REQUEST to a VS , then VS convert that HTTP_REQUEST to HTTPS and send to the intended NODE.
Also , this should be in full proxy architecture where we will be having two sessions , Client ---> F5 for HTTP and then F5 --->server with HTTPS .
Would this be achievable and if yes , how can we get this via IRULE or some other means .
I parse through askf5 and devcentral BUT couldn’t see any reference that MATCH my requirement .
Thanks again
Deepak
Hi Deepak,
  • Create a virtual server with port 80.
  • Assign http profile.
  • Assign serverssl profile. Don’t assign clientssl.
  • Assign pool with 443 ports members.
Ok the requirement is below .
when client make a request to the VIP URL http://www.example.com:8003/ngi/testentsys-m2p-lgmgmt-masterdata/entsys/m2p/lgmgmt/v1/commodities/:commodityId SHOULD route to AWS cloud NODE https://test.abcdef-ent-syz.com/testentsys-m2p-lgmgmt-masterdata/entsys/m2p/lgmgmt/v1/commodities/:commodityId . there are like 100 Web URL behind this NODE. So i think i need to use here an IRULE which will check for one URI string “/ppf” , STRIP that string and attach the REST URI request to HOST test.aausyd-ent-syz.com .
CLIENT_REQUEST to VIP ----> http://www.example.com:8003/ppf/testentsys-m2p-lgmgmt-masterdata/entsys/m2p/lgmgmt/v1/commodities/:commodityId
VIP to SERVER -----> https://test.abcdef-ent-syz.com/testentsys-m2p-lgmgmt-masterdata/entsys/m2p/lgmgmt/v1/commodities/:commodityId
NO redirection SHOULD be in full proxy .
i have written an irule BUT it returning me a RESET
if {([string tolower [HTTP::host]] equals “www.example.com:8003”) && [HTTP::uri] starts_with “/ppf” } {
HTTP::header replace “Host” “test.abcdef-ent-syz.com”
HTTP::uri [string map [list “/ppf” “” ] [HTTP::uri]]
node 10.10.10.1 443
So my question is , can this be achievable .
iRule looks normal.
Is there another iRule in the Virtual Server?
Can you investigate /var/log/ltm?
Hi ,
SORRY it works now . It happens that at server end there is a firewall blocking the traffic when request is initiated from F5 which is now sorted .
Thanks for the help again .
