A site is configured on IIS7 boxes. A client has added BlueCoat SG Proxy on their end. The calls that are going through that proxy get successful responses from the site behind Nginx and exact same calls receive 404.4 (No handler configured) when the site is placed behind the F5.
The site is fully setup on the F5. A virtual server is configured mapped to a pool forwarding requests to back-end webservers in LTM. The site is also setup in GTM. We don’t have tcpdump installed.
Hi, If everything is configured on the F5 and the traffic actually reaches your web servers, then the most likely thing is that the domain name (the host header) when the requests get to your web servers is not recognised by your web servers. This seems to me like what the message “no handler configured” means. I’m more familiar with Apache myself, but this seems like the explanation.
Thanks for looking. Here is more info on the issue. We confirmed that non-encrypted traffic (http) from the BlueCoat proxy receives 200 status from wen servers. The same requests via https are getting 404.4
Could be that the Blue Coat isn’t permitting the F5’s IP address to retrieve content from it. Has the client investigated the Blue Coat as a possible culprit? I’ve seen Blue Coats block traffic from newly configured load balanced content through LTMs before. Ran into the issue a couple weeks ago actually.
Thanks for looking into this, Cory. The site is currently configured on one web server in each data center in LTM. I have pinned the site to one DC using fallback IP LB method. I did request the client to verify the proxy inbound rules though.
The issue is still present, but now we know exactly what’s happening when the client sends requests. We analyzed packets of good (200) and bad (404) responses. Bad requests are bad because the GET packets contain the domain name pre-pended to the URI. Examples:
My guess is this is a configuration issue on the client’s proxy and I will ask them to verify that. But could someone please help me come up with an iRule that would remove the “https://mySite.com” portion from the request the client is sending?
