AppWorld DC Booth Kiosk Generator
Welcome to AppWorld, community! You may or may not be with us in person, but you can watch this thread for iRules that are either generated or described by the Distributed Cloud AI Assistant.
AI-Generated iRule
Prompt: Compress HTTP responses only for clients that send an Accept-Encoding: gzip header and for text content types
Generated iRule (by F5 Distributed Cloud AI Assistant):
    # Check if the client sent an Accept-Encoding header with gzip
    if {[HTTP::header "Accept-Encoding"] contains "gzip"} {
        # Check if the content type is text
        if {[HTTP::header "Content-Type"] starts_with "text/"} {
            # Enable gzip compression for the response
            HTTP::header insert "Content-Encoding" "gzip"
            # Compress the response body
            set response_body [HTTP::response body]
            set compressed_body [gzip $response_body]
            HTTP::response body $compressed_body
AI-Generated iRule
Prompt: Parse an HTTP Authorization header to extract a Base64-encoded username and log it for audit purposes
when HTTP_REQUEST priority 500 {
    # Retrieve the Authorization header
    set auth_header [HTTP::header "Authorization"]
    # Check if Authorization header exists and starts with "Basic "
    if { $auth_header ne "" && [string tolower [string range $auth_header 0 5]] eq "basic " } {
        # Extract the Base64-encoded token by removing "Basic " prefix
        set b64_token [string range $auth_header 6 end]
        # Attempt to decode the Base64 token safely
        if { [catch {b64decode $b64_token} decoded_creds] == 0 && $decoded_creds ne "" } {
            # Extract username by splitting decoded string at the first colon
            if { [regexp -- {^([^:]+):} $decoded_creds -> username] } {
                # Log the extracted username for audit purposes
                log local0. "Extracted username from Authorization header: $username"
F5, Inc. ("F5") disclaims all liability in connection with any output generated by the AI Assistant ("Output") or use thereof, including without limitation any negative business impact caused by your use of Output to administer, direct, configure or control the operation and functioning of any F5 products. Output is provided "as is" without any warranties of any kind.
AI-Generated iRule
Prompt: Rate-limit HTTP requests per client IP using a subtable, allowing 30 requests per 60 seconds
    # Define maximum allowed requests per client IP
    set threshold 30
    # Define the time window in seconds for rate limiting
    set interval 60
    # Identify the client IP
    set client_ip [IP::client_addr]
    # Define subtable name for this client
    set table_name "req_count_${client_ip}"
    # Increment request count for this client
    set count [table incr -subtable $table_name -- $client_ip]
    # On first request, set the timeout for this client's counter
    if { $count == 1 } {
        table timeout -subtable $table_name -- $client_ip $interval
    # If request count exceeds threshold, respond with HTTP 429
    if { $count > $threshold } {
        HTTP::respond 429 content "Too Many Requests" noserver
        return
AI-Generated iRule
Prompt: Persist connections to the same pool member based on a JSESSIONID cookie value
    # Check if the JSESSIONID cookie exists
    if {[HTTP::cookie exists "JSESSIONID"]} {
        # Get the value of the JSESSIONID cookie
        set session_id [HTTP::cookie "JSESSIONID"]
        # Persist the connection to the pool member based on the session ID
        persist uie session_id
AI-Generated iRule
Prompt: Block HTTP requests that contain SQL injection patterns in the URI or query string
Unfortunately, the AI assistant is unable to answer this question as the F5 Distributed Cloud documentation does not include this information.
AI-Generated iRule
Prompt: Mirror a copy of all TCP traffic to a clone pool for intrusion detection analysis
when CLIENT_ACCEPTED {
    # Store the original destination address
    set original_dest [IP::client_addr]
    # Send a copy of the traffic to the clone pool for analysis
    pool clone_pool
when SERVER_DATA {
    # Send the server response to the clone pool as well
    pool clone_pool
when CLIENT_DATA {
    # Send the client request to the clone pool
    pool clone_pool
AI-Generated iRule
Prompt: Rewrite the Location header in 301/302 redirects to change the scheme from HTTP to HTTPS
AI-Generated iRule
Prompt: Terminate idle TCP connections that have been inactive for more than 300 seconds with a graceful close
when CLIENT_ACCEPTED priority 500 {
    # schedule a timer to close the connection after 300 seconds (300000 ms)
    set idle_timer [after 300000 {
        # gracefully close the TCP connection
        TCP::close
when CLIENT_CLOSED priority 500 {
    # cancel the scheduled idle timeout if the connection closes first
    if { [info exists idle_timer] } {
        after cancel $idle_timer
        unset -- idle_timer
AI-Generated iRule
Prompt: Redirect clients to a certificate enrollment page if no client SSL certificate is presented
when CLIENTSSL_CLIENTCERT {
    if { [SSL::cert count] == 0 } {
        # No client certificate presented, redirect to enrollment page
        HTTP::redirect "https://example.com/certificate-enrollment"
iRule Explanation - from the iRules Toolbox
Source: redirect_non_ssl_on_port_443.txt
# Create an F5 BIG-IP iRule that enforces HTTPS connections and directs users to a login page. The rule should check if the connection is encrypted by attempting to get the SSL cipher version. For unencrypted connections, log the detection and redirect to the HTTPS version of the Login.jsp page. For encrypted connections, allow the request to proceed but redirect requests for the root path to the Login.jsp page. Include error handling for the SSL cipher check and extract the hostname without port number when constructing redirect URLs.
    # Try to get the SSL cipher version and catch any errors
    # This checks if the connection is encrypted (SSL/TLS)
    if {([catch {SSL::cipher version} result]) || $result eq "none"} {
        # Log that we detected an unencrypted request
        log local0. "\: $result. Redirecting unencrypted request."
        # Redirect to HTTPS version of the site, specifically to Login.jsp
        # getfield extracts the hostname without port number (if any)
        HTTP::redirect "https://[getfield [HTTP::host] : 1]/Login.jsp"
        # Exit the rule early
        return
    # If we reach here, the connection is encrypted
    # Log that we're allowing the encrypted request
    log local0. "\: $result. Allowing encrypted request."
    # If the request is for the root path "/"
    if {[HTTP::path] eq "/"} {
        # Redirect to the Login.jsp page
        # This ensures users going to the root are sent to the login page
Explanation (generated by F5 Distributed Cloud AI Assistant):
Objective
• Enforce that all client requests use HTTPS by detecting the SSL/TLS state.
• Redirect plain‐HTTP requests to the HTTPS Login.jsp page, logging the event.
• Allow encrypted requests to proceed but send clients hitting “/” to Login.jsp.
• Extract the hostname without the port when building redirect URLs and handle SSL check errors.
Execution Flow
• Event: when HTTP_REQUEST priority 500 fires on each HTTP request (docs: valid event).
• The rule runs [catch {SSL::cipher version} result] to test for an SSL/TLS cipher (docs: SSL::cipher version).
• If catch returns non‐zero (error) OR $result eq "none"
– Log detection of an unencrypted request.
– Redirect to https://[getfield [HTTP::host] : 1]/Login.jsp (uses getfield to strip port; docs: getfield syntax).
– return exits this event early (docs: return stops the current event).
• Otherwise (encrypted connection)
– Log that the encrypted request is allowed.
– If [HTTP::path] eq "/" (docs: HTTP::path returns the request path)
• Redirect to https://[getfield [HTTP::host] : 1]/Login.jsp.
Potential Logic Concerns
• The log commands use local0. without specifying a severity level (docs require <facility>.<level>). This will fail at runtime. (high confidence)
Overall Summary
This iRule correctly enforces HTTPS, handles SSL detection errors, and redirects root‐path requests to Login.jsp while preserving the hostname. Fixing the log facility syntax will ensure proper logging.
F5, Inc. (“F5”) disclaims all liability in connection with any output generated by the AI Assistant (“Output”) or use thereof, including without limitation any negative business impact caused by your use of Output to administer, direct, configure or control the operation and functioning of any F5 products. Output is provided “as is” without any warranties of any kind.
AI-Generated iRule
Prompt: Log HTTP request and response headers to a remote syslog server in a structured key-value format
    # Log the incoming HTTP request headers to the syslog server
    set request_headers [HTTP::request_headers]
    set log_message "HTTP Request: [format_headers $request_headers]"
    log local0. "$log_message"
when HTTP_RESPONSE {
    # Log the outgoing HTTP response headers to the syslog server
    set response_headers [HTTP::response_headers]
    set log_message "HTTP Response: [format_headers $response_headers]"
# Helper function to format headers as key-value pairs
proc format_headers {headers} {
    set formatted ""
    foreach {key value} [array get headers] {
        set formatted "$formatted$key: $value; "
    return $formatted
AI-Generated iRule
Prompt: Reject SSL connections using TLS versions older than 1.2 with a TCP reset
when CLIENTSSL_HANDSHAKE priority 500 {
    # Get the TLS version from the current SSL cipher
    set tls_version [SSL::cipher version]
    # Reject connection if TLS version is older than 1.2
    if { $tls_version eq "SSLv2" or $tls_version eq "SSLv3" or $tls_version eq "TLSv1" or $tls_version eq "TLSv1.1" } {
        reject
SO COOL to see irule automation in action at appworld2026
AI-Generated iRule
Prompt: Inject a JavaScript analytics snippet into HTML response bodies before the closing </body> tag
when HTTP_RESPONSE priority 500 {
    # Check if Content-Type header exists and contains "text/html"
    if { [HTTP::header exists "Content-Type"] && [string tolower [HTTP::header "Content-Type"]] contains "text/html" } {
        # Get Content-Length header value if present, else set to 0
        if { [HTTP::header exists "Content-Length"] } {
            set content_length [HTTP::header "Content-Length"]
            set content_length 0
        # Collect the entire response body based on Content-Length or up to 1MB if unknown or large
        if { $content_length > 0 && $content_length < 1048576 } {
            HTTP::collect $content_length
            HTTP::collect 1048576
when HTTP_RESPONSE_DATA priority 500 {
    # Define the JavaScript analytics snippet to inject
    set js_snippet "<script>/* Analytics snippet here */</script>"
    # Get the full response body payload
    set content [HTTP::payload]
    # Search for the closing </body> tag case-insensitively
    if {[regexp -nocase -- {</body>} $content match body_tag_start]} {
        # Insert the JavaScript snippet before the closing </body> tag
        regsub -nocase -- {</body>} $content "${js_snippet}</body>" new_content
        # If no </body> tag found, append the snippet at the end
        append content $js_snippet
        set new_content $content
    # Replace the payload with the modified content
    HTTP::payload replace 0 [HTTP::payload length] $new_content
    # Update the Content-Length header to the new payload length
    HTTP::header replace "Content-Length" [string length $new_content]
    # Release the modified payload to continue processing
    HTTP::release
Source: cookie_encryption_gateway.txt
  # Exposed passphrase, but this key can be synchronized to the peer LTM
  set PASSPHRASE "secret"
  # Private passphrase, but it isn't synchronized.  On LTM failover to
  # its peer, applications relying on the encrypted cookies will break.
  # set passphrase [AES::key]
  foreach { cookieName } [HTTP::cookie names] {
    HTTP::cookie decrypt $cookieName $PASSPHRASE
    HTTP::cookie encrypt $cookieName $PASSPHRASE
Objective
• Define a shared passphrase on connection setup.
• Decrypt all HTTP cookies arriving from clients.
• Encrypt all HTTP cookies sent back in responses.
• Ensure backend sees plaintext cookies while clients store encrypted ones.
Execution Flow
• when CLIENT_ACCEPTED priority 500
– set PASSPHRASE "secret" establishes a cookie encryption key per connection (see set command docs).
• when HTTP_REQUEST priority 500
– [HTTP::cookie names] returns all cookie names.
– HTTP::cookie decrypt $cookieName $PASSPHRASE decrypts each cookie before passing to the server.
• when HTTP_RESPONSE priority 500
– [HTTP::cookie names] again lists all cookies (including newly set ones).
– HTTP::cookie encrypt $cookieName $PASSPHRASE encrypts each cookie before sending to the client.
Overall summary: This iRule transparently decrypts client cookies for internal use and re-encrypts them on the way back, using a static passphrase initialized at connection time.
AI-Generated iRule
Prompt: Encrypt a session cookie value on the response and decrypt it on subsequent requests for cookie security
    # Encrypt the session cookie value before sending it to the client
    set session_cookie [HTTP::cookie "session"]
    set encrypted_cookie [encrypt $session_cookie]  # Call to a custom encrypt function
    HTTP::cookie "session" $encrypted_cookie
    # Decrypt the session cookie value on subsequent requests
    set encrypted_cookie [HTTP::cookie "session"]
    if { $encrypted_cookie ne "" } {
        set session_cookie [decrypt $encrypted_cookie]  # Call to a custom decrypt function
        HTTP::cookie "session" $session_cookie
AI-Generated iRule
    # Get the TLS version string of the negotiated cipher
    if { $tls_version eq "SSLv2" || $tls_version eq "SSLv3" || $tls_version eq "TLSv1" || $tls_version eq "TLSv1.1" } {
        reject
        return
AI-Generated iRule
Prompt: Block DNS queries for domains matching a blocklist datagroup and return NXDOMAIN
AI-Generated iRule
Prompt: Select a specific pool member based on a query string parameter value (e.g., ?server=web01)
    # Check if the query string contains the parameter 'server'
    if {[HTTP::query] contains "server="} {
        # Extract the value of the 'server' parameter
        set server_name [getfield [HTTP::query] "server" "="]
        # Select the pool member based on the server_name
        if {$server_name eq "web01"} {
            pool web01_pool
        } elseif {$server_name eq "web02"} {
            pool web02_pool
            # Default pool if no match
            pool default_pool
        # Default pool if 'server' parameter is not present
        pool default_pool
