Priority group activation on GTM.
Hello All,
I need to configure active standby configuration on GTM pool level, only one VS should be UP and second should be standby if one vs is down then traffic should pass to another VS and i can see there is one option Minimum-up Members but i do not know how to use it as a priority group activation on GTM level.
If any one has any article or config suggestion please share.
Many thanks in advanced for your time and consideration.
@Militza   Hello,  Have you seen this article?
Configure a standby pool member to process traffic when primary pool member goes down
If you’re referring to the WIDE IP pools that contain the virtual servers discovered from server objects, you can use “Global Availability.” This load-balancing method allows the F5 to always resolve the request from the first entry (the active one) and only respond with the second entry if the first one fails.
If this is not the case, and you’re talking about the “Delivery > Load Balancing > Pools” configuration to load balance traffic across two DNS servers, you can follow the link shared by Jmtaylor. The pool configuration is similar to the LTM pool setup. In this scenario, you can use the basic Priority Group Activation with a condition of “less than one” if you have only two members.
