LTM - Pool members active standby failover
we have a requirement for Application server SLB as below mentioned scenario
Server-A and Server-B will be in the pool member
Server-A will be active and Server-B will be standby in the pool Member
if Server-A goes down the traffic will go on Server-B and  the traffic could not switch back if Server-A will comes online again. the switch back can happen only if the server-B goes offline.
is there any possibility to achieve the above scenario in BIG-IP LTM.
First, you need to configure Priority Group activation: myF5
This is a great feature when you want apply ( Active/Standby ) scenario on Pool level.
secondly:
you need to enable Manual resume feature to prevent the traffic from being return to the down pool member when it become up again, this feature is configured on health monitor level , so I recommend to create a customized health monitor instead of the default one.
Here the Manual Resume feature: myF5
IF you don’t want this solution however I recommend to proceed with my first approach , but there is an irule to do that , please review this Article on DevCenteral: Priority Group Activation ( Preemption question) | DevCentral
@vadivelan
Please consider Mark as Solution if the reply helped solve your problem.
Thanks.
