irules and HTTP/HTTPS pools
is there a way to get an irule/vsa capable of routing to backend pools which are both http and https (one of each).
If I enable a server ssl profile on the VSA, it breaks http pools, and vice versa.
Or is creating a new VSA the only way to support this config?
thanks in advance.
You can use the SSL::disable command to disable the server SSL profile if the selected pool is HTTP. There are a few examples on the wiki page:
SSL::disable
http://devcentral.f5.com/wiki/default.aspx/iRules/ssl\_\_disable
Aaron
