Hi, is it possible (and if so some advice for a newbie) to have a virtual server listening on port https and depending on the url, forwarding on either http or https to the pool.
so https://site.com/url1 is forwarded to the pool on https but requests to https://site.com/url2 would be forwarded to the pool on http.
Many thanks for your time..
Yes. there are many ways to do it. serverssl can be selectively enable or disable for the urls.
E.g. one of the option is to apply serverssl on the VIP and disable it for /url2.
iRule option:
switch -glob [string tolower [HTTP::uri]] {
"/url1*"
pool https_pool
"/url2*"
SSL::disable serverside
pool http_pool
} default {
return
ltm policy option:
rule 1-
http uri --> path starts with --> /url1 --> at request
action: forward traffic to https_pool
rule2;
http uri --> path start with --> /url2
action1: disable server ssl --> at request
action2: forward traffic to http_pool
Yes that worked, many thanks for your quick response…
