irule to a pool using SSL
What I am trying to achieve is to send traffic to a specific pool based on the uri. Which works fine on http, the issue I have is when I use the irule on https.
I have to assign an http profile to enable me to add an irule, when I add the standard http profile we have the site browses very slowly or gets connection time out. I am assuming I need a different setting in the profile or + ssl profile (server).
Does anyone have any info on what the settings should be in an http profile (to allow ssl to work) or pointers to it? (FYI - if I add the http profile with no irule it does not work - so it’s not the irule).
thanks in advanced
Does it actually browse very slowly and or sometimes time out, or does it just not work when you add the HTTP profile? There could be several things amiss here:
1. If you need to re-encrypt traffic to the back end server and you don’t have a server SSL profile applied, it’s more than likely not going to work at all.
2. If you have a 443 virtual server pooling to 443 servers, with no SSL profiles (SSL pass through), then you cannot add an HTTP profile. In fact if you’re not terminating the client side SSL then you cannot use an HTTP profile.
3. You said “the standard http profile we have”. Does that mean you’ve modified the default HTTP profile? If so, what did you change?
4. It could be that the application uses absolute addressing and cannot handle the https:// namespace when it’s listening on http://. You need to look at what the server is sending to the client. If it’s sending references to http:// resources (redirects, page objects, etc.), which the client cannot access, then you’ll need to make provisions for that.
Excellent info there.. working through it now… here is some more info if it helps:
The http profile is the standard one - http - if this is enabled then the site times out
If I use a ssl server profile -
wom-default-serverssl
(and no http profile) it works fine, add the http profile and it stops.
Think I am getting closer:
this is pretty close, looks like I need to forward - but how do I do that based on the string in http:uri? What should I modify to make this irule a forward?
set uri [string tolower [HTTP::uri]]
if { $uri starts_with “/abc” } {
pool W_APool_443
} else { pool W_BPool_443 }
I’m not sure that applies.
If you intend to decrypt the SSL on the client side, you need to apply a client SSL profile to the VIP. If you need to re-encrypt to the server, you need a server SSL profile applied to the VIP. If you intend to decrypt and then re-encrypt, then you need both client and server SSL profiles applied. If you’re attempting to manage layer 7 (HTTP) data on an encrypted channel without first decrypting, then it will most certainly fail. You cannot see HTTP::uri in an HTTP_REQUEST event if you haven’t applied a client SSL profile.
So, how is your VIP configured with respect to SSL encryption/decryption?
“So, how is your VIP configured with respect to SSL encryption/decryption?” - are you talking about client and server profiles? If so, I have tried a combination of all the standard ones and they do not seem to work.
are there other settings for encryption/decryption?
Thinking about it.. I’d need the cert on the f5 to be able to unencrypt. That’s not on there…
I feel like my problem is that! Thanks for your time Kevin.. this stuff is all new to me (if that wasn’t obvious)
Let’s step back and reassess.
Are clients contacting your virtual server on port 443 via HTTPS? If so you need a client SSL profile applied to the virtual server and 443 in the destination port of the virtual server.
Are the web servers behind the BIG-IP also listening on 443 (HTTPS)? If so you need a server SSL profile applied to the virtual server and the pool members should be configured with their respective IPs and port 443. If they are not HTTPS servers, then do NOT apply a server SSL profile.
At this point, and with no HTTP profile applied, you should be able to access your servers through the BIG-IP VIP. If that works, apply the generic HTTP profile without the iRule. If that works, apply the iRule.
Can you also post your iRule?
“I’d need the cert on the f5 to be able to unencrypt”
Assuming you’re referring to the client SSL profile, you can use the generic default certificate and key for now. You’ll get a browser trust error, but you’ll still be able to negotiate SSL.
Correct KS.. the BIG-IP is listening on 443 and forwards to 443. If I add client and server ssl profiles I get the trust error. The problem is these are public web sites being served so can not have trust issues :frowning:
What I am trying to do is direct traffic to specific pools based on the uri. We have migrated part of the site to a new server, when we move it all then this will not be a problem as all traffic can be forwarded (saying that.. this has prompted me to seriously consider ssl offloading) and no uri check will happen.
this is my irule (all names changed to protect the innocent).. so if you hit www.mysite.com/abc you will go to one set of servers.. anything else you hit the originals.
pool W_APool_443
So to summarize then, if you don’t SSL offload, you can’t apply an HTTP profile or use this iRule. If you do SSL ofload, you’ll need to get the certificate and key from each web server behind the BIG-IP to stop the trust errors.
Posted By Kevin Stewart on 02/21/2013 08:34 AM
A paragraph I was hoping to not see :slight_smile: Tavm for the help.
Hi nastymatt,
Actually what Kevin is telling you is a good thing and not that difficult at all.
1. Export SSL Certificate from Server.
2. Import SSL Certificate into the LTM Certificate Store (Local Traffic → SSL Certificates → Import)
3. Create new SSL Profile (Local Traffic → Profiles → SSL → Client) and assign the Certificate and Key that you imported.
4. Apply SSL Profile (Client) made in Step 3 to the Virtual Server, Apply SSL Profile (Server) to be the default “serverssl”.
5. Apply an HTTP Profile (you could use the default if you wish)
6. Assign iRule to the Virtual Server.
This should solve your entire problem and allow your HTTPS Virtual Server to behave just like your HTTP Virtual Server with no SSL Certificate mismatch errors.
The biggest things to remember are:
1. You cannot use an iRule that uses HTTP Methods (when HTTP_REQUEST or when HTTP_RESPONSE) without an HTTP Profile assigned to the Virtual Server.
2. You cannot use an HTTP Profile on encrypted traffic, so if you need an iRule you need to at least Decrypt the traffic (SSL Profile (Client)).
3. If the downstream servers are expecting an secure session then you will need to apply a SSL Profile (Server). This tells the LTM that the downstream server wants to talk securely, so expect it.
Excellent details Michael. I will be putting this into practice next week.. so i might be back :slight_smile:
This was a very helpful stream of info.
This is good information. I am new to F5 and have found the online info great but I need some help. I have setup SSL offloading but my website returns HTTP not HTTPS. Current version is 11.4.0. I imported my cert and key into SSL profile (client), created my pool using port 80 on the pool members, created my VS using port 443. I’m using the http profile. I am not familiar with iRules but maybe I need a redirect? When I ping I am hitting the vip.
Any assistance is appreciated. Thanks,
When you say “my website returns HTTP not HTTPS”, are you referring to redirects and document object references pointing to the http:// URL? If so, that’s actually a pretty common issue when offloading SSL, and there are two things you can do about it:
  1. There’s an option in the HTTP profile called “Redirect Rewrite”. This option is designed to catch redirects from the server and rewrite the http:// in the Location header to https://. This only applies to redirect (ie. 30x) responses.
  2. An iRule and STREAM profile to catch all of the document object references in the HTTP payload. Apply a generic (empty) STREAM profile to the VIP and the following iRule:
        HTTP::header remove Accept-Encoding
        STREAM::disable
    when HTTP_RESPONSE {
        if { [HTTP::header Content-Type] contains "text" } {
            STREAM::expression {@http://@https://@}
            STREAM::enable
A STREAM is basically like a regular expression evaluator, but in hardware, so it’s super fast. The above will find any reference to the string http:// in the HTTP response paylaod and replace it with https://. You may need to be more explicit in your search/replace if you have strings that you don’t want replaced.
Kevin,
Thank you so much. I was able to use the HTTP profile redirect/rewrite and that worked. I did try Option 2 but wasn’t successful. I think I had details incorrect. I will work on that later. Patty
If you’re redirecting within https, you could do something like this:
    if { [HTTP::path] eq "/" } {
     HTTP::respond 301 Location "https://abc.xyz/BankingApp"
Thanks for the feedback. I will implement and revert
