hi all,
so we have an application that requires connecting to a specific URL, but this application only supports “http”. we happen to have an “https” URL that this application needs to connect to, so I though of creating a VIP that listens on port 80, and then plugged the URL as a pool member on port 443.
this seems to get the initial connection to work, but then the URL sends a redirection to the client, and Yes it is “https” so when the client attempts to connect to the VIP on 443, of course it fails.
so I was wondering if there’s a way to resolve this problem using an iRule.
anyone can help with this
For your 443 virtual server, you can apply a client SSL profile and terminate the SSL at the BIG-IP. Not applying a server SSL profile will allow the BIG-IP to talk native HTTP to the server, so this should satisfy your requirement if I understand it correctly.
Use the same pool for both of your virtual servers (80 and 443).
Though why would the server be sending a redirect to HTTPS if it doesn’t support SSL enabled connections?
I figured a picture is worth $5 so here it is.
so the failure happens when the client receives an https URL and then it attempts step 4 and then it dies right there.
Okay, so the web server needs to talk SSL. So you need this:
Virtual server on port 80, apply the irule _sys_https_redirect (this is a stock iRule included in all recent LTM code versions). This will redirect all HTTP to HTTPS.
Virtual server on port 443. Apply an appropriate client SSL profile to handle the client side SSL.
Pool with the server as a 443 member. Apply this to your 443 virtual server.
That should be all you need.
I think you already have this, but ensure you also have a server SSL profile applied to your 443 virtual server.
there’s only one VIP, which is the one that listens on 80 .
I guess the main problem here is that the redirect comes back from the web server as https, so we’ll need to somehow change this URL to http before sending it to the client.
Your diagram shows the redirect from the server to the client coming back as HTTPS. It seems like your server wants to use SSL, so it’s best to just redirect the client to HTTPS at the BIG-IP and maintain SSL between the BIG-IP and server. This way no redirection is needed from the server.
Just create a 443 virtual server as I mentioned above and apply the iRule to your 80 virtual server.
the client is not capable of connecting over SSL, which is the reason for creating the VIP over 80 that way it always stays connected to 80 while F5 VIP is connected to 443 in the back-end.
I hope I am making sense
Yes, I think I understand your situation now. So it sounds like you need something to rewrite the response from the server back to the client to change HTTPS to HTTP. Something like this:
This will require the assignment of a stream profile to your virtual server.
This is the iRule I got from the link:
Check if response type is text if {[HTTP::header value Content-Type] contains “text”}{
Replace http:// with https://
STREAM::expression {@http://@https://@}
Enable the stream filter for this response only
STREAM::enable
if { [HTTP::is_redirect] } {
HTTP::respond 302 Location [string map { http:// https:// } [HTTP::header Location]]
it seems as if it’s doing the opposite of what I am trying to accomplish.
is it?
Yes, you’ll want to swap http:// and https://
if {[HTTP::header value Content-Type] contains "text"} {
Replace https:// with http://
STREAM::expression {@https://@http://@}
STREAM::enable
HTTP::respond 302 Location [string map { https:// http:// } [HTTP::header Location]]
Entire iRule:
Save the requested host value
set host [string tolower [HTTP::host]]
Disable the stream filter by default
STREAM::disable
when HTTP_RESPONSE {
Check if response type is text and host isn't null
if {[HTTP::header value Content-Type] contains "text" and $host ne ""}{
Replace http://$host with https://$host
STREAM::expression "@https://$host@http://$host@"
STREAM::enable
HTTP::respond 302 Location [string map "https://$host http://$host" [HTTP::header Location]]
Cory,
Thanks for your help buddy.
I will test this later after business hours and report back.
MJ
Remember, you’ll first have to apply an empty stream profile to your virtual server, and then apply the iRule.
Cory,
I was able to test this and it’s still not redirecting. I took a pcap and found something that seems interesting:
GET /Doc1/Login.aspx HTTP/1.1
Accept: image/jpeg, image/gif, image/pjpeg, application/x-ms-application, application/xaml+xml, application/x-ms-xbap, /
Accept-Language: en-US
User-Agent: Mozilla/4.0 (compatible; MSIE 8.0; Windows NT 6.1; WOW64; Trident/4.0; SLCC2; .NET CLR 2.0.50727; .NET CLR 3.5.30729; .NET CLR 3.0.30729; .NET4.0C; .NET4.0E)
Accept-Encoding: gzip, deflate
Host: HostName.DomainName.com
Connection: Keep-Alive
HTTP/1.1 200 OK
Server: Microsoft-IIS/7.5
X-Powered-By: ASP.NET
X-UA-Compatible: IE=9
Date: Fri, 09 May 2014 17:15:47 GMT
Content-Length: 263
the redirect seems to be part of the payload through a java script, so I think this is the reason the iRule didn’t work with this VIP.
Good morning Cory,
any more thoughts about a solution for this issue? I am kind of stock and not sure what else to do at this point.
Was the capture you took on the server side? How are you determining that the issue could be Javascript related?
What are you seeing on the client side?
the capture was done on BigIP over ssh: tcpdump -ni 0.0:nnn -s0 host x.x.x.x -w /var/tmp/external.cap & tcpdump -ni 0.0:nnn -s0 ‘(host x.x.x.x)’ -w /var/tmp/internal.cap &
I was testing the access from a windows server in the internal network.
Can you run a Wireshark capture from your Windows server and see what the client is receiving from the BIG-IP?
yes sir will do and report back soon.
