How to use literals starting with "$" in iRule
I need to pass client certificate to WebSphere so the application can perform SSL based authentication. I following this article myF5
However in WebSphere App Server the headed for client certificate is $WSCC. But if I code iRule like this
HTTP::header insert $WSCC [b64encode [SSL::cert 0]]
$WSCC is treated as a variable WCSS and the rule is broken
How do I get around this issue?
Genna
Hi Genna,
you can escape the ‘$’ character with a ‘\’. This should work:
    HTTP::header insert "\$WSSC" [b64encode [SSL::cert 0]]
KR
Daniel
to prevent variable substitution, you can replace double quotes by curly braces.
    HTTP::header insert {$WSSC} [b64encode [SSL::cert 0]]
Stan
