https://support.abc.int/supportnet/application.jsp#support/32
https://pxl.saas.supportsystems.com/assystnet/application.jsp#services/48
trying to create an irule to redirect the top site to the bottom site however the “#” is being interperted as another command and giving us an error. any way we can redirect the uri with the # sign?
@tthomaPXL anything from the “#” and after is not passed to the server and is a client side only piece of information. This was recently discussed in the following post.
https://community.f5.com/t5/technical-forum/want-to-block-uri-containing-special-character-but-the-irule/td-p/323383
In addition to what @Paulius says, you can try the iRule below.
# Disable the stream filter by default
STREAM::disable
# LTM does not uncompress response content, so if the server has compression enabled
# and it cannot be disabled on the server, we can prevent the server from
# sending a compressed response by removing the compression offerings from the client
HTTP::header remove "Accept-Encoding"
if { [HTTP::uri] starts_with "/f5/anchor_link_redirect" } {
set href [b64decode [URI::query [HTTP::uri] href]]
if { $href equals "https://support.abc.int/supportnet/application.jsp#support/32" } {
HTTP::redirect "https://pxl.saas.supportsystems.com/assystnet/application.jsp#services/48"
else {
HTTP::redirect $href
when HTTP_RESPONSE {
if { ([HTTP::header "Content-Type"] starts_with "text/html") } {
STREAM::expression {@</title>@</title>
<script>
document.addEventListener(`click`, e => {
const origin = e.target.closest(`a`);
if (origin && origin.href.indexOf('#') > -1) {
const base64_href = btoa(origin.href);
window.location.href = '/f5/anchor_link_redirect?href=' + base64_href;
</script>@}
STREAM::enable
For more info on how to use this iRule see: https://community.f5.com/t5/codeshare/python-script-to-test-if-a-f5-big-ip-is-vulnerable-to-cve-2023/ta-p/323614
Have fun,
--Niels
