How to add Syslog headers to Bot Defense logs over HSL? (Missing formatting options)
Hi DevCentral Community,
I am running into issue with logging Bot Defense events to our SEIM (AIsaac) and could use some advice on best practices.
  • We have logging profile configured to send both Application Security (ASM) and Bot Defense logs to a Remote Publisher.
  • The Publisher is currently tied to a Remote HSL(High-Speed-Logging) destination.
The Problem:
For standard ASM WAF logs, we can easily format the log string directly in the GUI under the Applications Security logging tab.
However, under the Bot Defense logging tab, there is no option to customize the log format. Because it is sending directly to a raw HSL destination, the Bot Defense logs are arriving at out SEIM completely stripped of standard Syslog headers. Without these headers, the SEIM cannot parse the logs correctly.
My Questions:
  1. Is inserting a Syslog formatted destination before the HSL destination the official way to inject standard headers into Bot Defense logs?
  2. Is there any hidden tmsh command or iRule method to actually customize the Bot Defense log payload format, or is the payload structure strictly fixed by the system?
Hello @zaid_bhati
I saw your post hasn’t had responses, wanted to check if since you posted if you have gotten the answers from other sources and if you have if you could please provide an update to your post. If not then we can assist in checking if support is an option to assist you.
-Melissa
