GTM Pools
Is there a trick to disabling a GTM pool used by a wide IP?
I can enable them just fine when they have been manually disabled, but for some reason the iControl interface just ignores the disable state and nothing happens.
Here is copy of the code in question:
@gtmPools = ('prod1','prod2','prod3','prod4');
  @gtmEnabled=(1,1,1,1);
  @gtmDisabled=(0,0,0,0);
          $gtm = SOAP::Lite
                  -> uri('urn:iControl:GlobalLB/Pool')
                  -> proxy("https://$gtmHost:443/iControl/iControlPortal.cgi");
          eval { $LBVirtual->transport->http_request->header
                  'Authorization' =>
                  'Basic ' . MIME::Base64::encode("$sUID:$sPassword", '')
          $soapResponse = $gtm->set_enabled_state(
                  SOAP::Data->name(pool_names => [@gtmPools]),
                  SOAP::Data->name(states => [@gtmDisabled])
          @gtmStatus = @{$soapResponse->result};
The only difference between enable and disable code is the variable @gtmEnabled is used instead.
EDIT: I guess it would help to mention that this is perl.
In V9, you’ll have to use the string literals for the enumeration types. So, your code should look like this:
@gtmEnabled = ('STATE_ENABLED', 'STATE_ENABLED', 'STATE_ENABLED', 'STATE_ENABLED');
 @gtmDisabled = ('STATE_DISABLED', 'STATE_DISABLED', 'STATE_DISABLED', 'STATE_DISABLED');
That’s assuming that your code will create an array. I usually work through Perl by trail and error and I don’t have access to my dev machine right now.
If that doesn’t work, this should:
my @gtmPools;
 push @gtmPools, "prod1";
 push @gtmPools, "prod2";
 push @gtmPools, "prod3";
 push @gtmPools, "prod4";
 my @gtmEnabled;
 push @gtmEnabled, "STATE_ENABLED";
 my @gtmDisabled;
 push @gtmDisabled, "STATE_DISABLED";
Hope this helps…
-Joe
Unfortunately that didn’t work either.
Here is the SOAP request
xmlns:xsi="http://www.w3.org/1999/XMLSchema-instance"
   xmlns:SOAP-ENC="http://schemas.xmlsoap.org/soap/encoding/"
   xmlns:SOAP-ENV="http://schemas.xmlsoap.org/soap/envelope/"
   xmlns:xsd="http://www.w3.org/1999/XMLSchema"
   SOAP-ENV:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/">
  prod1
  prod2
  prod3
  prod4
  STATE_DISABLED
  STATE_DISABLED
  STATE_DISABLED
  STATE_DISABLED
And the response from the GTM:
xmlns:E="http://schemas.xmlsoap.org/soap/envelope/"
          xmlns:A="http://schemas.xmlsoap.org/soap/encoding/"
          xmlns:s="http://www.w3.org/2001/XMLSchema-instance"
          xmlns:y="http://www.w3.org/2001/XMLSchema"
          xmlns:iControl="urn:iControl"
          E:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/">
            xmlns:m="urn:iControl:GlobalLB/Pool">
Everything set to disabled is still enabled though.
It looks as if it should work. I just tested it with this code
http://devcentral.f5.com/wiki/default.aspx/iControl/PerlGTMPool.html
Click here
In this code I’m only passing in a single pool, but I tested by adding multiple pools manually in the code and it worked fine.
Here’s the SOAP Trace for the set_enabled_state:
xmlns:soapenc="http://schemas.xmlsoap.org/soap/encoding/"
    xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
    xmlns:xsd="http://www.w3.org/2001/XMLSchema"
    xmlns:soap="http://schemas.xmlsoap.org/soap/envelope/">
        gtm_pool
        STATE_DISABLED
Can you run this script against your BIG-IP. If you pass in no pool name, it will return a list. Here’s a test run I ran:
> .\PerlGTMPool.pl bigip 443 user pass
gtm_pool_2
gtm_pool
> .\PerlGTMPool.pl bigip 443 user pass gtm_pool
STATE_ENABLED
> .\PerlGTMPool.pl bigip 443 user pass gtm_pool disabled
STATE_DISABLED
> .\PerlGTMPool.pl bigip 443 user pass gtm_pool enabled
STATE_ENABLED
STATE_ENABLED
If this still isn’t working then this looks like a bug on your BIG-IP but I’m unaware of an open issue on this. Let me know what you find out.
-Joe
Well, I ran your script which worked.
I then changed the SOAP line at the top so I can get the XML output.
Without making any modifications I ran mine to get the XML output and compare, and for some reason it’s now working.
This is puzzling and slightly unreliable at the moment.
I’m going to have to keep an eye on this.
