GTM pool is OFFLINE even if pool members are UNKNOWN
Maybe someone can clarify me this situation. I didn’t found it in documentation.
  • generic host (with no monitors) has two virtual servers (also no monitors here). the state of server and virtual servers is unknown (that expected).
  • state of the pool is OFFLINE (why?? this is not clear for me), but (all two) members are UNKNOWN
  • wide IP is OFFLINE because poll has no available members (members are unknown, not unavailable)
  • dns response to wide ip returns two IPs (IP adresses of both members).
    • it’s ok in this case, because return code on failure is (by default) disabled
    • when I enable ‘return code on failure’, response is empty
  • Note: when one member is disabled (or down based on temporary monitor), dns response return only one IP - IP of the unknown member. That’s correct, but pool state and wide ip state are offline.
My question is: Why is pool state OFFLINE when pool members states are UNKNOWN?
I think he should be unknown. When the same situation occurs on LTM, state of pool is unknown, not offline. Does GTM behave differently??
TMOS version: 17.1.1.3
Here is simple test configuration:
# gslb domain (wide ip)
gtm wideip a /testTenant/testApp/test.my.local {
    pools {
        /testTenant/testApp/testPool { order 0 }
# gslb pool
gtm pool a /testTenant/testApp/testPool {
    alternate-mode global-availability
    fallback-mode none
    load-balancing-mode global-availability
    members {
        /Common/server1:vs1 { member-order 0 }
        /Common/server1:vs2 { member-order 1 }
# gslb servers
gtm server /Common/server1 {
    datacenter /Common/testDc devices {
        0 {
            addresses { 10.1.1.1 { } }
    prober-fallback none
    product generic-host
    virtual-servers {
        vs1 { destination 10.1.1.11:0 }
        vs2 { destination 10.1.1.12:0 }
I found article describing this behavior (myF5). It answers my question, but it’s still confusing to me.
