Hello community,
is there any way to check if the pool members offline/down (e.q. network or server error) or disabled (by a monitor during a maintenance) using a iRule?
The background would be the delivery of an event-specific user information page.
Network or server error => Error Page with Helpdesk-Support infos
Maintenance => simply maintenance site
Thanks & BR
René
You could use something like this
if { {[active_members poolName] < 1} } {
HTTP::respond 200 content {
<html>
<head>
<title>Apology Page</title>
</head>
<body>
We are sorry, but the site you are looking for is temporarily out of service<br>
If you feel you have reached this page in error, please try again.
</body>
</html>
for more flexibility you could also use iFiles
Hello,
thanks for the answer. But that’s don’t solve the problem. Funktion “active_members” can’t differentiate to pool state offline or disabled.
I don’t want to display just one maintenance message, but two different ones (depending on the pool status). I have no idea if that’s even possible.
<If> {
Pool state → offline → Error Page with Helpdesk-Support infos
<else> {
Pool state → disabled → simply maintenance site
Have not tested but might work with something like this
of course adjust names, members and messages
if { [LB::status pool my_pool member 10.1.1.1 80] eq "down" &&
[LB::status pool my_pool member 10.1.1.2 80] eq "down" }{
<html>
<head>
<title>Error Page</title>
</head>
<body>
whatever you want to say plus links
</body>
</html>
} elseif { [LB::status pool my_pool member 10.1.1.1 80] eq "session_disabled" &&
[LB::status pool my_pool member 10.1.1.2 80] eq "session_disabled" }{
<html>
<head>
<title>Maintenance Page</title>
</head>
<body>
</body>
</html>
else {
pool my_pool
Thank you. Working fine for me
