Hello,
I was wondering if there is anything required to be enabled in GTM to allow REST API calls vi tools like curl.
I would like to get pool members of a certain pool; preferable the output should be in json format.
Ideally, the authentication token should be received/generated first to use it in any consequent API call.
Thanks,
Version:
| BIG-IP 14.1.4.6 Build 0.0.8 Point Release 6 |
