Problem this snippet solves:
Here’s a little sample perl script that illustrates how to get and set the enabled state of a GTM Pool.
Code :
#!/usr/bin/perl
# The contents of this file are subject to the "END USER LICENSE AGREEMENT FOR F5
# Software Development Kit for iControl"; you may not use this file except in
# compliance with the License. The License is included in the iControl
# Software Development Kit.
# Software distributed under the License is distributed on an "AS IS"
# basis, WITHOUT WARRANTY OF ANY KIND, either express or implied. See
# the License for the specific language governing rights and limitations
# under the License.
# The Original Code is iControl Code and related documentation
# distributed by F5.
# The Initial Developer of the Original Code is F5 Networks,
# Inc. Seattle, WA, USA. Portions created by F5 are Copyright (C) 1996-2004 F5 Networks,
# Inc. All Rights Reserved. iControl (TM) is a registered trademark of F5 Networks, Inc.
# Alternatively, the contents of this file may be used under the terms
# of the GNU General Public License (the "GPL"), in which case the
# provisions of GPL are applicable instead of those above. If you wish
# to allow use of your version of this file only under the terms of the
# GPL and not to allow others to use your version of this file under the
# License, indicate your decision by deleting the provisions above and
# replace them with the notice and other provisions required by the GPL.
# If you do not delete the provisions above, a recipient may use your
# version of this file under either the License or the GPL.
#use SOAP::Lite + trace => qw(method debug);
use SOAP::Lite;
use MIME::Base64;
use Math::BigInt;
BEGIN { push (@INC, ".."); }
use iControlTypeCast;
# Validate Arguments
my $sHost = $ARGV[0];
my $sPort = $ARGV[1];
my $sUID = $ARGV[2];
my $sPWD = $ARGV[3];
my $sPool = $ARGV[4];
my $sEnable = $ARGV[5];
my $sProtocol = "https";
if ( ("80" eq $sPort) or ("8080" eq $sPort) )
$sProtocol = "http";
if ( ($sHost eq "") or ($sPort eq "") or ($sUID eq "") or ($sPWD eq "") )
&usage();
sub usage()
my ($sCmd) = @_;
print "Usage: GlobalLBPool.pl host port uid pwd pool [enable|disable]\n";
exit();
# Transport Information
sub SOAP::Transport::HTTP::Client::get_basic_credentials-->
return "$sUID" => "$sPWD";
$Pool = SOAP::Lite
-> uri('urn<!--:iControl:GlobalLB/Pool')-->
-> proxy("$sProtocol://$sHost:$sPort/iControl/iControlPortal.cgi");
eval { $Pool->transport->http_request->header
'Authorization' =>
'Basic ' . MIME::Base64::encode("$sUID:$sPWD", '')-->
if ( $sPool eq "" )
&GetPoolList();
else
if ( $sEnable eq "" )
&GetPoolState($sPool);
else
&SetPoolState($sPool, $sEnable);
sub GetPoolList()
$soapResponse = $Pool->get_list();
&checkResponse($soapResponse);
@pools = @{$soapResponse->result};
foreach $pool (@pools)
print "$pool\n";
# GetPoolState
sub GetPoolState()
my ($pool) = (@_);
$soapResponse = $Pool->get_enabled_state(
SOAP::Data->name(pool_names => [$pool])
@states = @{$soapResponse->result};
foreach $state (@states)
print "$state\n";
sub SetPoolState()
my($pool, $state) = (@_);
print " Setting pool '$pool' to state '$state'\n";
if ( $state eq "enabled" )
$state = "STATE_ENABLED";
else
$state = "STATE_DISABLED";
my @gtmPools;
push @gtmPools, $pool;
# push @gtmPools, "gtm_pool_2";
my @gtmEnabled;
push @gtmEnabled, $state;
# push @gtmEnabled, $state;
$soapResponse = $Pool->set_enabled_state(
SOAP::Data->name(pool_names => [@gtmPools]),
SOAP::Data->name(states => [@gtmEnabled])
&GetPoolState($pool);
# checkResponse
sub checkResponse()
my ($soapResponse) = (@_);
if ( $soapResponse->fault )
print $soapResponse->faultcode, " ", $soapResponse->faultstring, "\n";
exit();
