Problem this snippet solves:
This is a simple cli script used to collect all the WideIP, LB Method, Status, State, Pool Name, Pool LB, Pool Members, Pool Fall back, Last Resort pool info in CSV format.
A sample output would be like below,
One can customize the code to extract other fields available too. Check out my other codeshare of LTM report.
Note: The codeshare may get multiple version, use the latest version alone. The reason to keep the other versions is for end users to understand & compare, thus helping them to modify to their own requirements. Hope it helps.
How to use this snippet:
Login to the GTM/DNS, create your script by running the below commands and paste the code provided in snippet,
tmsh
create cli script gtm-config-parser
Delete the proc blocks, so it looks something like below,
create script gtm-config-parser {
## PASTE THE CODE HERE ##
and paste the code provided in the snippet.
Note: When you paste it, the indentation may be realigned, it shouldn’t cause any errors, but the list output would show improperly aligned.
Feel free to delete the tab spaces in the code snippet & paste it while creating, so indentation is aligned properly.
And you can run the script like below,
tmsh run cli script gtm-config-parser > /var/tmp/gtm-config-parser-output.csv
And get the output from the saved file, open it on excel. Format it & use it for audit & reporting.
cat /var/tmp/gtm-config-parser-output.csv
Feel free to add more elements as per your requirements.
For version 13.x & higher, there requires a small change in the code. Refer the comments section. Thanks to @azblaster
Code :
proc script::run {} {
puts "WIP,LB-MODE,WIP-STATUS,WIP-STATE,POOL-NAME,POOL-LB,POOL-MEMBERS,POOL-FB,LASTRESORT-POOL"
foreach { obj } [tmsh::get_config gtm wideip all-properties] {
set wipname [tmsh::get_name $obj]
set wippools [tmsh::get_field_value $obj pools]
set lbmode [tmsh::get_field_value $obj "pool-lb-mode"]
set lastresort [tmsh::get_field_value $obj "last-resort-pool"]
foreach { status } [tmsh::get_status gtm wideip $wipname] {
set wipstatus [tmsh::get_field_value $status "status.availability-state"]
set wipstate [tmsh::get_field_value $status "status.enabled-state"]
foreach wippool $wippools {
set pool_name [tmsh::get_name $wippool]
set pool_configs [tmsh::get_config /gtm pool $pool_name all-properties]
foreach pool_config $pool_configs {
set pool_lb [tmsh::get_field_value $pool_config "load-balancing-mode"]
set pool_fb [tmsh::get_field_value $pool_config "fallback-mode"]
if { [catch { set member_name [tmsh::get_field_value $pool_config "members" ]} err] } {
set pool_member $err
set pool_member ""
set member_name [tmsh::get_field_value $pool_config "members"]
foreach member $member_name {
append pool_member "[lindex $member 1] "
puts "$wipname,$lbmode,$wipstatus,$wipstate,$pool_name,$pool_lb,$pool_member,$pool_fb,$lastresort"
Tested this on version:
11.6
