ERR_SPDY_PROTOCOL_ERROR when enabling SPDY
Hi !
I use BIG-IP 11.6.0 and try to enable SPDY. I have a VS with an Access Policy that uses an ‘External Logon Page’ action.
My config:
ifile with a custom login page
VS with:
  • No Client SSL profile
  • An AP that starts with an ‘External Logon Page’ action with a Server URI ‘/login’
  • A pool select irule used to direct traffic to the login ifile
switch -regexp -- [string tolower [HTTP::path]] {
    "^/login(/|$)" {
    HTTP::respond 200 content [ifile get login-form] ...
    ... (pool selects for actual services) ...
  • In front of this VS I have another VS. It has a Client SSL profile
Without SPDY
When I don’t have SPDY enabled on my front VS everything works:
  • /myservice 302 →
  • /my.policy 200 OK (APM will initiate a POST to the external logon page, /login)
  • /login 200 OK. (/login is an iFile)
  • user enters credentials (/login POST’s these to /my.policy) →
  • /my.policy 302 →
  • /myservice (and I’m logged in)
With SPDY
When I enable SPDY on the front VS, things break:
  • /myservice 302 →
  • /login ( This request is made, but bad/no response is received by the client)
  • Chrome shows ‘not available, ERR_SPDY_PROTOCOL_ERROR’. dev tool shows ‘CAUTION: Provisional headers are shown’ in place of request headers. No reponse headers are shown
  • FF shows ‘Secure Connection Failed’
  • IE works
In the ltm log I can see:
  • the AP in the inner VS has started
  • the /login ifile has been served
  • the outer VS has fired a HTTP_RESPONSE event
  • There are no log entries in apm or ltm other than those i make myself
  • if I go directly to the custom login page (i.e. https://mysite.no/login) I get the same error.
  • If I repeat the request for the custom login page, it works (!)
I make no other change than enabling SPDY. If I disable SPDY again everything works normally.
Any tips on how to figure out this issue? I find nothing in the BIG-IP logs, error messages from the browsers are very generic, and since SPDY only works over HTTPS listening in on the traffic is difficult.
