Remote User Management - LDAP Client Cert
Has anyone successfully deployed LDAP using client cert authentication to the BIG-IP TMUI? I see the guide though it is not very intuitive so I was curious if anyone would be willing to share their configuration? From what I hear, there have been bugs prior to 13.1 which have now been resolved to allow this capability. Thanks!
Below is my current config though for some reason when modifying authentication methods for remote users, httpd stops with the error “err httpd[4467]: [error] Unable to configure verify locations for client authentication”
root@(bigip1)(cfg-sync Standalone)(ModuleNotLicensed::Active)(/Common)(tmos) show running-config auth
auth cert-ldap system-auth {
    bind-dn CN=Administrator,CN=Users,DC=test,DC=com
    bind-pw $M$O4$RMnF/vBcoSHr/NYmQqr7Yw==
    debug enabled
    login-attribute sAMAccountName
    login-filter [a-zA-Z0-9]\\\\w*(\\\?=@)
    login-name altSubjectName=Othername
    search-base-dn DC=test,DC=com
    servers { 10.1.20.10 }
    ssl-cname-field san-other
    ssl-cname-otheroid 1.3.6.1.4.1.311.20.2.3
    sso on
auth password-policy { }
auth remote-role {
    role-info {
        BIGIPadmins {
            attribute CN=BIGIPadmins,OU=Groups,DC=test,DC=com
            console tmsh
            line-order 1
            role administrator
            user-partition All
auth remote-user { }
auth source {
    type cert-ldap
auth user admin {
    description "Admin User"
    encrypted-password $6$CEtjm9Te$.VC8lUQnU1NcT0Udsgq6jtR.SSbASW2//e3tfxmRXzb4nv7E1E.Bb0KotT2C..rbRMpBgbdJNs1sBRFdiBHXm1
    partition Common
    partition-access {
        all-partitions {
            role admin
    shell none
Below is my httpd config.
root@(bigip1)(cfg-sync Standalone)(ModuleNotLicensed::Active)(/Common)(tmos) list sys httpd all-properties
sys httpd {
    allow { All }
    auth-name BIG-IP
    auth-pam-dashboard-timeout off
    auth-pam-idle-timeout 12000
    auth-pam-validate-ip on
    description none
    fastcgi-timeout 300
    fips-cipher-version 0
    hostname-lookup off
    include none
    log-level debug
    max-clients 10
    redirect-http-to-https disabled
    request-body-max-timeout 0
    request-body-min-rate 500
    request-body-timeout 60
    request-header-max-timeout 40
    request-header-min-rate 500
    request-header-timeout 20
    ssl-ca-cert-file /Common/CurrentCACert
    ssl-certchainfile none
    ssl-certfile /etc/httpd/conf/ssl.crt/server.crt
    ssl-certkeyfile /etc/httpd/conf/ssl.key/server.key
    ssl-ciphersuite ECDHE-RSA-AES128-GCM-SHA256:ECDHE-RSA-AES256-GCM-SHA384:ECDHE-RSA-AES128-SHA:ECDHE-RSA-AES256-SHA:ECDHE-RSA-AES128-SHA256:ECDHE-RSA-AES256-SHA384:ECDHE-ECDSA-AES128-GCM-SHA256:ECDHE-ECDSA-AES256-GCM-SHA384:ECDHE-ECDSA-AES128-SHA:ECDHE-ECDSA-AES256-SHA:ECDHE-ECDSA-AES128-SHA256:ECDHE-ECDSA-AES256-SHA384:AES128-GCM-SHA256:AES256-GCM-SHA384:AES128-SHA:AES256-SHA:AES128-SHA256:AES256-SHA256:ECDHE-RSA-DES-CBC3-SHA:ECDHE-ECDSA-DES-CBC3-SHA:DES-CBC3-SHA
    ssl-include none
    ssl-ocsp-default-responder http://dc.test.com/ocsp
    ssl-ocsp-enable on
    ssl-ocsp-override-responder off
    ssl-ocsp-responder-timeout 300
    ssl-ocsp-response-max-age -1
    ssl-ocsp-response-time-skew 300
    ssl-port 443
    ssl-protocol all
    ssl-verify-client require
    ssl-verify-depth 10
httpd error logs
[root@bigip1:ModuleNotLicensed::Active:Standalone] httpd  tail -f httpd_errors
Jan 15 15:18:09 bigip1 err httpd[25050]: [error] Unable to configure verify locations for client authentication
Jan 15 15:21:45 bigip1 err httpd[26019]: [error] Unable to configure verify locations for client authentication
Jan 15 15:27:40 bigip1 err httpd[27394]: [error] Unable to configure verify locations for client authentication
Jan 15 15:27:45 bigip1 err httpd[27472]: [error] Unable to configure verify locations for client authentication
Jan 15 15:33:17 bigip1 err httpd[28861]: [error] Unable to configure verify locations for client authentication
Jan 15 16:37:18 bigip1 err httpd[10615]: [error] Unable to configure verify locations for client authentication
Jan 15 16:39:27 bigip1 err httpd[11132]: [error] Unable to configure verify locations for client authentication
Jan 15 16:41:48 bigip1 err httpd[11924]: [error] Unable to configure verify locations for client authentication
Jan 15 16:47:06 bigip1 err httpd[13281]: [error] Unable to configure verify locations for client authentication
Jan 15 16:47:12 bigip1 err httpd[13347]: [error] Unable to configure verify locations for client authentication
Ok, progress. After modifying most/if not all objects in httpd config, I configured the CA cert to none and httpd now starts again. Not quite sure what the issue could have been with the CA cert. However, I am now here. I am prompted for a client certificate and receive these errors.
Jan 15 20:14:35 bigip1 err httpd[23742]: [error] [client 10.1.1.81] Re-negotiation handshake failed: Not accepted by client!?, referer: https://bigip1.test.com/banner.html
Jan 15 20:14:49 bigip1 err httpd[23819]: [error] [client 10.1.1.81] Certificate Verification: Error (20): unable to get local issuer certificate
Jan 15 20:14:49 bigip1 err httpd[23819]: [error] [client 10.1.1.81] Re-negotiation handshake failed: Not accepted by client!?, referer: https://bigip1.test.com/banner.html
Jan 15 20:14:49 bigip1 err httpd[23742]: [error] [client 10.1.1.81] Re-negotiation handshake failed: Not accepted by client!?, referer: https://bigip1.test.com/banner.html
Unable to perform an SSLdump on the management interface and unable to decrypt traffic using the private key using Wireshark. Has anyone run into issues with compatibility between httpd cipher suites and Windows 2012?
hello DeV,
The error you mention (Unable to configure verify locations for client authentication ) most often has to do with the SSLCertificateChainFile or the SSLCACertificateFile being unable to be read and parsed… You have to be sure that this certificate is in PEM format! we ofen have issue with DER and Base64 in this use case…
Regards,
Greetings,
My configuration is far simpler than yours, I’ll post it below. For me, the ssldump output wasn’t very helpful. I used both the /var/log/httpd/httpd_errors and /var/log/secure logs to troubleshoot.
BIG-IP config:
 list sys httpd
sys httpd {
    ssl-ca-cert-file /Common/bigip_ca
    ssl-ocsp-default-responder http://172.24.171.29:2345
    ssl-ocsp-enable on
    ssl-ocsp-override-responder on
 list auth cert-ldap
    bind-dn cn=admin,dc=ldap,dc=test,dc=net
    bind-pw $M$nq$CDOcADlm/Mkwy8MIU1/eLg==
    login-attribute uid
    login-filter "[a-z]{5}"
    login-name cn
    search-base-dn ou=People,dc=ldap,dc=test,dc=net
    servers { 172.24.171.2 }
    sso on
LDAP entry:
 kevin, People, ldap.test.net
dn: uid=kevin,ou=People,dc=ldap,dc=test,dc=net
objectClass: inetOrgPerson
objectClass: posixAccount
objectClass: shadowAccount
uid: kevin
cn: kevin
displayName: kevin
SSL certificate:
Subject: C=US, ST=Washington, L=Seattle, O=Example, OU=Example BIGIP Admins, CN=kevin
Hope this is helpful!
Kevin
I have continued to look at the httpd logs though below is all I get.
Jan 18 05:42:05 ip-10-10-10-10 err httpd[5837]: [error] [client 10.1.20.25] Re-negotiation handshake failed: Not accepted by client!?, referer: https://bigip1.ad.lab/xui/
Jan 18 05:42:06 ip-10-10-10-10 err httpd[5837]: [error] [client 10.1.20.25] Re-negotiation handshake failed: Not accepted by client!?, referer: https://bigip1.ad.lab/tmui/Control/form?__handler=/tmui/system/user/authconfig&__source=finished&__linked=false&__fromError=false
Defintely SSL related. So, a few SSL related things I ran into:
1) Ensure the OCSP service up and reachable.
2) Ensure you are using SHA256 for signing.
3) Ensure the CA cert has the "extendedKeyUsage = OCSPSigning" extension.
4) Ensure the CA cert is in the certificate database. httpd checks the CA cert first for some reason.
Hope these points offer some help!
Kevin
For troubleshooting purposes I am attempting to perform certificate based authentication within APM using the same certificates as I am in TMUI. I exported the BIG-IP certificate and key to create a client ssl profile. I imported the CA cert and added that to the trusted and advertised fields of the client SSL profile. SSL profile has ignore for client certificate and ODCA is configured to required. I am prompted for a certificate though based on the logs from my ssl profiel no certificate has been passed.
Ltm::ClientSSL Profile: BIGIPClientSSL
Virtual Server Name                                               N/A
Bytes                                                         Inbound  Outbound
  Encrypted                                                     48.1K    235.9K
  Decrypted                                                     24.6K    143.8K
Connections                                                      Open   Maximum  Total
  Native                                                            0         6     55
  Compatibility                                                     0         0      0
  Total                                                             0         7     55
Certificates/Handshakes
  Valid Certificates                                                0
  Invalid Certificates                                              0
  No Certificates                                                  55
  Mid-Connection Handshakes                                         0
  Secure Handshakes                                                55
  Current Active Handshakes                                         0
  Insecure Handshakes Accepted                                      0
  Insecure Handshakes Rejected                                      0
  Insecure Renegotiations Rejected                                  0
  Mismatched Server Name Rejected                                   0
  Extended Master Secret Handshakes                                55
Protocol
  SSL Protocol Version 2                                            0
  SSL Protocol Version 3                                            0
  TLS Protocol Version 1.0                                          0
  TLS Protocol Version 1.1                                          0
  TLS Protocol Version 1.2                                         55
  DTLS Protocol Version 1                                           0
Key Exchange Method
  Anonymous Diffie-Hellman                                          0
  Diffie-Hellman w/ RSA Certs                                       0
  Ephemeral Diffie-Hellman w/ DSS Certs                             0
  Ephemeral Diffie-Hellman w/ RSA Certs                             0
  Ephemeral ECDH w/ ECDSA Certs                                     0
  Ephemeral ECDH w/ RSA Certs                                      17
  Fixed ECDH w/ ECDSA Certs                                         0
  Fixed ECDH w/ RSA signed Certs                                    0
  RSA Certs                                                         0
Ciphers
  Advanced Encryption Standard (AES)                               55
  Advanced Encryption Standard Galois Counter Mode (AES-GCM)        0
  Digital Encryption Standard (DES)                                 0
  Rivest Cipher 2 (RC2)                                             0
  Rivest Cipher 4 (RC4)                                             0
  IDEA (old SSLv2 cipher)                                           0
  Camellia                                                          0
  No Encryption                                                     0
Message Digest Method
  Message Digest 5 (MD5)                                            0
  Secure Hash Algorithm (SHA)                                      55
  No Message Authentication                                         0
SSL Hardware Acceleration
  Full                                                              0
  Partial                                                           0
  None (Software)                                                  55
Session Cache
  Current Entries                                                   0
  Hits                                                             38
  Lookups                                                          66
  Overflows                                                         0
  Invalidations                                                    28
Records
  In                                                              116
Thank you Kevin. It is now working. The 4 issues that I think bit me are below.
  1. In my lab environment I did not add OCSP to the AIA extension of the CA. I reissued cert once added and then ran certutil -URL path\dev.cer. Validated the certificate against my OCSP responder.
  2. Imported CA cert in PEM format. (Base64)
  3. Configured OCSP override on the BIG-IP client-cert ldap config.
  4. Enabled Nonce support on my OCSP responder.
Unfortunately my frustration let me to modify all four without trying to determine which of the actually resolved it. None the less, thank you for taking the time to respond to my question. Your input is greatly appreciated.
I’m really happy to hear this is working for you and congratulations, this was no easy feat! =)
Thanks also for letting us know.
Kevin
Long ago post but I wanted to comment that after a very frustrating week of working with this I found the openssl ocsp man page response verification requires the issuer of the response is also the issuer of the certificate.  So if you overload a heirarchy with just the one OCSP responder it could never pass.  From their page you can run openssl to create a new PEM that has trusted extensions for the issuer of the OCSP responder.
openssl x509 -in ocspCA.pem -addtrust OCSPSigning -out trustedCA.pem
And F5 / LTM will not do the LDAP authentication with the ssl-ocsp-enable set to “off” It will just skip the LDAP lookup.
