Hello Everyone,
I want to disable SQL injection and XML Tagging attack for this url:-
“http://mybase.com/users/profile”.
So is there any iRule for disabling SQL injection and XML tagging for the above URL.
Thanks.
Hello Everyone,
Thanks.
I would recommend F5’s ASM module to handle this, assuming the application/website cannot be fixed to address the problem. Escaping input at the app level works a lot better than pattern matching at the network level.
Thanks Mimlo for your input…
Vivek, could you stick to your initial post please ? i provided you with an answer here for SQL injection unnblock: DevCentral - An F5 Technical Community
next step for you is to identify the attack type form XML tagging and add it with a or in the matching condition.
thanks.
