We are not blocking the traffic based on URLs. Currently wildcard is allowed in the ASM policy. We would like to disable specific signature for some of the URLS.
myF5 would still help us here? If we add the specific URL and disable signature for them?
Yes you can definitely add urls and apply different signatures to them.
Hi, Yes you can test this with Disable attack signature checks for specific entities. Please refer the first point (Disable attack signatures for URLs)
Hello @nurairtt91 ,
I noticed that Aswin was able to confirm the article you provided. If this has helped you we would greatly appreciate an update to your post as solved. However, if it has not please update with any follow up or additional questions you may have for the community to assist.
-Melissa
