Hello,
Is it possible to disable Attack Signature checks for a specific URL and to let the ASM act normally for others.
Example :
/aaa/bbb/ccc => do not check for Attack Signature
/* => act normally
Thanks for helping
Hello,
Example :
/* => act normally
Thanks for helping
You can disable attack signatures for a specific parameter on the properties screen for the parameter…
The ability to disable/enable attack signatures on a per-URL basis was introduced as a feature only in v13. Therefore, in v13 and above, you can create the URL as an Allowed URL (Explicit or Wildcard) and then configure the Overridden Security Policy settings within the Attack Signature tab for that URL.
In all versions prior to that, you can only make this exception on the parameter level or else it’ll need to be done globally for that policy. One other option, for these pre-13.x versions, would be to use the ASM::unblock iRule event.
These two links gives more insight regarding these iRule events:
https://devcentral.f5.com/wiki/iRules.ASM__unblock.ashx https://devcentral.f5.com/wiki/irules.asm__violation_data.ashx
