Debugging Flow Messages through MBLB
Hi all,
Using a virtual Server with MBLB Profile, the LTM knows internally how to deliver a TCP message from a client based on TCP connections . So, Is there a way to debug these events using irules?
Tks
just wondering if putting log in irule event is not helpful.
When you say “Debug these events”, what data is it you’re trying to obtain, exactly? As nitass said above, a log statement will likely net you some info, but it depends largely on what you’re looking for specifically.
Colin
Hi guys,
I need data information about how LTM deliver the message and how to correlate with the TCP connection. Considerong MBLB IS message-based oriented, how it works?
I’m working on a irule and using MBLB, but its impossible use some commands on events, like TCP::local_port on SERVER_DATA. Some commands works well when IRemove the MBLB, but I need to use it.
So I need a way to identify and debug message flow.
Tks in advance
doesn’t TCP::local_port in SERVER_DATA work?
this is mine.
root@(ve11a)(cfg-sync Changes Pending)(Active)(/Common)(tmos) list ltm virtual bar
ltm virtual bar {
    destination 172.28.20.111:7
    ip-protocol tcp
    mask 255.255.255.255
    pool foo
    profiles {
        mblb { }
        tcp { }
    rules {
        myrule
    source 0.0.0.0/0
    source-address-translation {
        type automap
    vs-index 23
root@(ve11a)(cfg-sync Changes Pending)(Active)(/Common)(tmos) list ltm pool foo
ltm pool foo {
    members {
        200.200.200.101:7 {
            address 200.200.200.101
        200.200.200.111:7 {
            address 200.200.200.111
root@(ve11a)(cfg-sync Changes Pending)(Active)(/Common)(tmos) list ltm rule myrule
ltm rule myrule {
    when CLIENT_ACCEPTED {
  TCP::collect
when CLIENT_DATA {
  log local0. "[IP::remote_addr][TCP::remote_port] > [IP::local_addr]:[TCP::local_port] payload=[TCP::payload]"
  TCP::release
  TCP::notify request
  TCP::collect
when SERVER_CONNECTED {
  TCP::collect
when SERVER_DATA {
  log local0. "[IP::local_addr]:[TCP::local_port] > [IP::remote_addr]:[TCP::remote_port] payload=[TCP::payload]"
  TCP::release
  TCP::notify response
  TCP::collect
[root@ve11a:Active:Changes Pending] config  tail -f /var/log/ltm
Aug 31 13:40:33 ve11a info tmm[1027]: Rule /Common/myrule : 172.28.20.1759863 > 172.28.20.111:7 payload=1
Aug 31 13:40:33 ve11a info tmm[1027]: Rule /Common/myrule : 200.200.200.14:59863 > 200.200.200.111:7 payload=1
Aug 31 13:40:34 ve11a info tmm[1027]: Rule /Common/myrule : 172.28.20.1759863 > 172.28.20.111:7 payload=2
Aug 31 13:40:34 ve11a info tmm[1027]: Rule /Common/myrule : 200.200.200.14:59863 > 200.200.200.101:7 payload=2
Aug 31 13:40:35 ve11a info tmm[1027]: Rule /Common/myrule : 172.28.20.1759863 > 172.28.20.111:7 payload=3
Aug 31 13:40:35 ve11a info tmm[1027]: Rule /Common/myrule : 200.200.200.14:59863 > 200.200.200.111:7 payload=3
Aug 31 13:40:36 ve11a info tmm[1027]: Rule /Common/myrule : 172.28.20.1759863 > 172.28.20.111:7 payload=4
Aug 31 13:40:36 ve11a info tmm[1027]: Rule /Common/myrule : 200.200.200.14:59863 > 200.200.200.101:7 payload=4
Hi Nitaas,
Yes, it’s working. But just when I remove MBLB profile. But I will do some tests on Monday, and I will post my Irule.
Tks in advance.
