we have requirement to block particular URL’s and URI.
can we block URL and URI in the APM provisioned F5 device.
Thanks,
RK
Thanks,
RK
Yes you can, even with just LTM
try something like this
when HTTP_REQUEST
switch -glob [ string tolower [HTTP::uri] ]
"/uri1" -
"/uri2"
drop
default
Hi @rkram_p ,
if you really want to use APM, you could use Per-Request Polices. Do as Kostas said, use iRules instead.
Cheers
Daniel
Hi @Injeyan_Kostas ,
Thank you for your response. can we use same format for to block whole URL?
RK
you can try somthing like this
when HTTP_REQUEST
switch -glob [ string tolower [HTTP::host] ]
"test.example.com"
"/uri1" -
"/uri2"
drop
default
"test2.example.com"
"/uri3" -
"/uri4"
drop
default
default
You can also use Local Traffic Policy. I try to only use iRule if a Local Traffic Policy can not be effective. Less CPU cost.
GUI path: Local Traffic → Policies → Policy List → Create
Use these settings:
