forwarding requests to APM based on URI.
Folks, We are trying to forwarding requests to APM based on URI. If the F5 sees something like /support and /helpdesk in the URI it should forward the http request to the APM engine. If not, simply forward it to the pool.
Thanks!! N.
Hi Guy,
Use this iRule :
        Check the requested HTTP uri
       switch -glob [string tolower [HTTP::uri]] {
              "/support*" -
              "/helpdesk*" {
                      Disable APM for these uri
                     ACCESS::disable
              default {
                      Enable APM for all other uris
                     ACCESS::enable
Hope it helps
Please mark it as answer if it works
Regards
BIG-IP APM Operations Guide for more info on clientless mode
Examples
# Check the requested HTTP path
switch -glob [string tolower [HTTP::path]] {
“/apm_uri1*” -
“/apm_uri2*” -
“/apm_uri3*” {
# Enable APM for these paths
ACCESS::enable
default {
# Disable APM for all other paths
ACCESS::disable
Thanks, we tried the above to disable the pre-defined access policy APM for  a few URLs:
but it keeps asking the credential again and again, it can not pass the login. any idea? thanks
By default if you put an access profile on a vip, it suppresses all of the HTTP_REQUEST events until after the session is started.
You can turn that suppression off using this irule command:
The reasoning about why it’s like this is so that admins can re-use “non APM” irules on an APM virtual and have them work without modification.
