APM checking for URI
I have created an APM policy that checks to is it the URI contains a specific URI.  If the URI is anything else then the fallback is to send the traffic.
example: fubar: Real people. Real fun. - the APM is looking for /admin and if present the traffic will then go to the next step is certificate prompt
if the URI contains anything else use the fallback to continue.  For example https://www.fubar.com/documents/invenioHealth the APM would use the fallback and just let the traffic pass
https://www.fubar.com/documents/invenioHealth in this case the F5 is sending a 302, instead of just sending the traffic through and then sends a FIN/ACK back to the source.
Hello @steven_normole
You should better just disable APM for unmatched uris
try something like this
    if { ![[HTTP::uri] starts_with "/admin"] } {
        ACCESS::disable
that solved that problem.  thank you
