Allowed URL with Parameter
Hello, everybody,
I have inferential problem. I have two URLs, one should be allowed and the other should not be allowed.
/prweb/*/!STANDARD?pyActivity= --> allowed
/prweb/*/!STANDARD --> not allowed
Now the F5 only recognizes the first part as URL and not the parameter. How can I get it that only the URL with the parameter can be called?
Already entered the parameter at the URL. But I can call both URLs.
Does anyone have an idea?
Thanks Udo
In ASM, there is no rule to deny url without parameter but only defining allowed parameters…
If you want to do it, you have to write an irule…
    if {!([string match [HTTP::path] "/prweb/*/!STANDARD"] && [HTTP::query] starts_with "pyActivity")} {
        drop
You can also do it within a LOCAL TRAFIC POLICY with same logic
I just built it.
Now I also get an Arlam when calling the page with the parameter.
