X-Forwarded-For HTTP Module For IIS7, Source Included!
For those who of you that are having problems with logging client addresses in their server logs because you are running your web servers behind a proxy of some sort, never fear, your solution i...
Published Dec 23, 2009
Version 1.0Jul 21, 2010
@Kyle B - not sure how to deal with that as I'd have to do some testing to try to simulate the IIS caching and I'm not sure how exactly to do that one. I'm no expert, I just patched this together and it worked for the test cases I had. Let me know if you find a solution to the server side caching and I'll get it integrated into the distribution.
@Kyle G - What "install" command were you referring to? I've only tested it with the IIS admin tool and configuring it in there. Also, are you sure you are using the correct build (64-bit). I'd also check that the file on disk has the correct permissions to allow the IIS account to be able to read it. I've seen this issue before that by increasing the permissions on the file allowed it to be loaded into IIS.
