Post-Quantum Cryptography: Building Resilience Against Tomorrow’s Threats
This is great, but is it supported in hardware or general-purpose CPU? Also, when will this arrive for XC?
Hi Walter_Kacynski ,
To make sure, I got your question right, if you need specific hardware to get PQC enabled, it's no, as long as you switch to v17.5+ you are able to use the new ciphers. Here;s the KB for the hardware/software compatibility
https://my.f5.com/manage/s/article/K9476
The current implemented standard is to make sure a compatiblity exist with classic cryptography, by using ECDH algorith encapsulated with Quuantum resistent cipher.
For XC query, let me check on this one and get back to you
- momahdyMay 14, 2025
Employee
The current support is through general-purpose CPU- Walter_KacynskiMay 14, 2025
Does F5 have any benchmarks on how much CPU will be consumed by activating these new ciphers on R-Series?
- momahdyMay 15, 2025
Employee
No current published numbers for this Cipher usag, will follow up and include that in the article once the figures are published.
