Nessus 6 XSLT Conversion for ASM Generic Scanner Import
It is important to understand while reading this, I am not an ASM SME...
The goal was to create a simple conversion of the Nessus Vulnerability Scan reports to import into ASM. The first step was ...
Published Sep 11, 2017
Version 1.0MichaelatF5
Employee
gbbaus_104974
Mar 25, 2019Historic F5 Account
@Mohanad
In your 'outputs file' (ie the one to be imported into ASM). Are any of the "URL" values blank?
You may be trying to import a HOST scan, and not a 'Web App' scan ?
As a test, even though a 'Host Scan' isnt appropriate for a Web App Firewall, enter a dummy url between the tags in the scan you are trying to import and see if the import error goes away.
