IIS X-Forward-For ISAPI Filter
A recent customer issue came up where they were load balancing servers but we unable to get the true client address logged in their IIS logs. They had their servers fronted by a BIG-IP and when clients would make requests the address passed to the server was the internal address and not that of the client.
This is a common issue with proxies and fortunately there is a standard for forwarding client information. It is the HTTP X-Forwarded-For header which is handled by most proxies. So, I set out to find an existing ISAPI filter to replace the c-ip (client ip) log value in IIS with the contents of the X-Forwarded-For header (if it exists). I was amazed to find that I couldn't find a single instance of any open source (or even commercial) filter that would do this.
So, I dug out Visual Studio and whipped up a filter that does just that. It's very basic and contains no user configuration so all you need to do is plug it into your Web Applications list of ISAPI Filters within the IIS Administration and you're set to go.
We've released the source under the iControl End User License Agreement (available in any iControl SDK download). You can download it here. If you find a way to optimize this filter, please let me know and I'll update the sources here.
After 24-hours of posting, a customer already returned some performance testing on the filter indicating that it only effected the traffic by less than 1 percent. I'm sure there are ways to optimize the memory allocation in the filter to speed this up a bit more, but I'll leave that for the community to work on.
Oh, and it should be noted that the X-Forwarded-For header isn't supported the same way across all proxy products so you'll want to make sure you test this out before using it. It is expecting the header to only contain an IP Address as it does a straight substitution on the value in the c-ip section of the log entry.
Enjoy!
-Joe
35 Comments
- GT92
Hi, I just saw you now have an HttpModule for the XFF, that's great! I went to GitHub the URL below but wasn't able to find the binaries. Hopefully I'm not an idiot :) What am I missing?
https://github.com/f5devcentral/f5-xforwarded-for/tree/master/HTTPModule
- NitinK
Employee
Attaching the installation file for "X-Forward-For ISAPI filter" mentioned as per the Article K4816, under the section "Microsoft IIS web server"
- Forrest_Shields
Evidently this can now be done natively in IIS 7+ (WinSvr2008+) without requiring an ISAPI filter.
In the article at LoadBalancer.org (http://blog.loadbalancer.org/iis-and-x-forwarded-for-header/) Rob Cooper discusses how you can now use "IIS Advanced Logging" installable feature to capture custom headers like X-Forwarded-For in the logs. - Unfortunately, I can't test that configuration right now. I've released the source for both the ISAPI filter and HTTP module if anyone can take a look and try to figure it out. When I get some free time in a couple of weeks, I'll dig in and see if I can reproduce it.
-Joe - If you are running on IIS7+ the I'd suggest you look at my native HTTP module.
devcentral.f5.com/.../...iis7-source-included.aspx
Although, if you are stuck on ISAPI, I have tested the ISAPI Filter on 64-bit IIS7. Not sure why IIS7.5 wouldn't work.
-Joe
- @Clive - Glad it worked out for you!
- I just rebuilt and tested with Win2k8-x64 and IIS7 and it works like a champ. The link in my post is updated with the latest build.
-Joe - Instead of writing the X-Forwarded address to the log, how can you modify the remote addrr variable to get replaced with the x-forwarded ip.
- Hope that helps out!
-Joe - There is no newer version as I haven't looked at this for years. The source should still be available if you want to recompile for yourself. The most likely issue of the dll not being able to be loaded is an issue with permissions. Select Properties on the .dll from explorer and give full control to all and see if it then loads.
-Joe
