Apr 07, 2010
If you are running on IIS7+ the I'd suggest you look at my native HTTP module.
devcentral.f5.com/.../...iis7-source-included.aspx
Although, if you are stuck on ISAPI, I have tested the ISAPI Filter on 64-bit IIS7. Not sure why IIS7.5 wouldn't work.
-Joe
