May 06, 2009
There is no newer version as I haven't looked at this for years. The source should still be available if you want to recompile for yourself. The most likely issue of the dll not being able to be loaded is an issue with permissions. Select Properties on the .dll from explorer and give full control to all and see if it then loads.
-Joe
