Active/Active load balancing examples with F5 BIG-IP and Azure load balancer
Multiple standalone devices, or cluster? Let's discuss what is possible and easily supportable in public cloud.
Background
A couple years ago I wrote an article about some practical considerations using Azure Load Balancer. Over time it's been used by customers, so I thought to add a further article that spe...
Updated Mar 11, 2024
Version 10.0MichaelOLeary
Employee
Joined May 15, 2019
awan_m
May 21, 2024Hi - i am trying to configure a Sync only device group F5 deployment in GCP - i have 2 single NIC f5s .
to setup device trust i need to have a NON Management ip address . can you help me understand how you set it up on your environment.
did you add a second ip to interval vlan on both devices and allowed communication on heartbeat ports between the 2 devices on that port ?
secondly how did you configure virtual servers - was it the same ip address on both devices ?
thanks
MichaelOLeary
Employee
Jul 18, 2024Hi awan_m
Yes, add a second network interface for the non-management traffic. Regarding the IP address, usually I have a different IP address on each device.
Please shoot me a message over this website if you want more help and we can email directly, thanks!!
Mike
