A Guide to Cohesive and Purpose-Built Security
Have you ever been to a concert? Think of all the security involved just for somebody to sing you a few songs. You can’t just have one person at the entrance to check your ticket and that’s it. You need security personnel, bag checkers, security cameras, etc. You can’t use a bag checker to monitor security cameras. In the same way, you can’t use a WAF to prevent sophisticated bots. If a concert needs purpose-driven solutions for individual concerns, so does your company and its applications.
Each attack vector requires a purpose-built solution- yet all these solutions need to work together in a cohesive manner. Customers commonly hear this and ask, is it really all vital? Do I need it all? Do these solutions work together? The answer is yes. It’s all vital in different ways, purpose-built problems require purpose-built solutions.
L7 Web Application Firewall - WAF
Many Web Application Firewalls (WAF) are focused on protecting against known L7 attacks that trigger various signatures to block malicious traffic, including things like the OWASP Top 10, Cross-Site Scripting, Malicious File Upload, etc. A WAF generally looks at malicious events occurring in the moment and blocks based on triggered signatures or detections. But to be more specific, a Layer 7 WAF scrutinizes all incoming web traffic, protecting your web application from malicious requests and ensuring that only legitimate traffic is allowed in.
Bot Mitigation
Now let’s look at bot mitigation as a strategy. A bot mitigation strategy needs to include a solution able to identify known bot networks while also providing strategies to accurately identify and prevent attackers with malicious intentions. Benign bots exist as well, but they include things like site crawlers or chatbots that people typically don’t care to protect against. Due to this, the bot mitigation strategy will not discuss these types of bots and instead focus on malicious bots. These types of attacks are incredibly difficult to detect since the attack is designed to interact with the application and emulate human behavior, utilizing automation to appear as though the application is being used as it is intended. Due to the nature of human-emulating and automated attacks, a purpose-built solution is necessary to analyze various pieces of telemetry to evaluate whether a user’s behavior is of human or automated origin. Examples of these malicious intentions include account takeovers, card cracking, or fraudulent purchases. These events can result in exposed PII, latency, and can cause your customers to lose faith in your company’s ability to handle their information.
Having both a WAF and a bot mitigation strategy work well together because a WAF blocks attackers trying to break into your application, whereas a bot mitigation strategy focuses on the other side of that coin, attackers using your application as it’s intended but with malicious intentions.
Behavioral Analysis
Another solution that should be in every security stack is a behavioral analysis-based solution. What does it pair well with? WAF and a bot mitigation strategy. As previously mentioned, a WAF typically blocks based on signatures, whereas a bot mitigation strategy blocks people using your application as it’s intended, but with malicious intent. A solution that utilizes machine learning to perform behavioral analysis is doing something else entirely. It uses the aforementioned machine learning to look at a variety of vectors to generate a baseline of your traffic and identify outliers based on the keys that you specify. From there, it can block and recognize when something malicious appears outside of the baseline. Utilizing that baseline, the solution can also look at events over time and catch attackers that might stop for now but come back later.
API Security
Next up, securing your API (Application Programming Interface) endpoints. APIs make requests to your application for information. But what happens when that API endpoint is unsecured? What happens when it contains sensitive data? It results in things like stolen credentials, unauthorized access, and data leaks, among other things. (The OWASP API Top 10 references some areas of concern as well) APIs are accessing data in your application all day long; therefore, your APIs need to be known and secured. Some people like to think of API Protection and WAF as the same thing and only requiring one solution. Personally, I do not. A WAF is typically looking at signatures, and yes, some API traffic might match those signatures, but not always. What if you’re expecting a POST, but you instead see a GET? Is a WAF signature going to catch that? Not likely. But a purpose-built API Protection solution with schema enforcement can certainly aid in solving that problem. API Security and WAF go hand in hand because they solve for vulnerabilities in different yet similar attack vectors, but they’re not the same.
Let’s recap. Do you need all the different security solutions? Can we create a cohesive picture of security? The answer is undoubtedly, yes. Let’s go back to our concert.
Concert - Security Personnel
Concert Security Personnel (Web Application Firewall): Throughout the venue, from the entrance to the concert floor, security personnel constantly watch the venue, keeping a lookout for disruptive behavior. If they spot something or someone that could disrupt the event, they step in to handle the situation. Think of a person walking in with a prohibited item like a weapon. We’d want to remove them because they had something matching the description of an item we do not allow at the concert. Similarly, a web application firewall (WAF) acts as security personnel for your web application, filtering out malicious traffic through the ability to look at a variety of signatures and ensuring nobody at the concert is matching those signatures and violations a WAF uses to mitigate threats.
Concert - Entrance Security
Entrance Security Personnel (Bot Mitigation Strategy): Concert security personnel are stationed at the entrance of the arena, checking everyone who comes in. They ensure that only the actual ticketed attendees are allowed inside. Bot mitigation works similarly by identifying application traffic with highly efficient signal sets, accurately thwarting automated threats, impersonations, account takeovers, and other automation-based threat vectors. Accurately blocking malicious automated traffic ensures only real users/humans get through. We only want to let ticketed people through the door.
Concert - Initial Screening
Initial Screening (Malicious User Mitigation): In many concerts today, pre-screening occurs where security scanners, bag checks, ID checks (depending on the venue) are performed. Those who are exhibiting non-compliance are turned away. This could even be screening for people who have had non-compliant behavior at prior concerts, letting the team know to keep an eye on them in case they might go back to their trouble causing ways. This way, if they cause problems for us later, we catch them quickly because we already know they could be troublemakers. Similarly, malicious user mitigation acts first. It involves monitoring your traffic and creating a baseline to identify and mitigate any users who exhibit malicious or suspicious behavior. This identification, driven by machine learning across various security signals, enforces a first-line defense strategy to block malicious activity.
Concert - Access Control
Access Control for Special Areas (API Security): There are other concert entrances where the band may enter or all the involved work to put on a concert flows through. These are further controlled and restricted areas within the venue such as backstage or the sound booths, that require special access passes. These passes are carefully controlled to ensure that only authorized personnel can enter these areas. API protection does the same thing for your web application’s interfaces, ensuring that only authorized systems and users can interact with your APIs, therefore protecting sensitive data and functionalities from unauthorized access.
Just like you need all the security personnel at a concert to feel secure, you need it all to keep your applications secure.
Summary
Each solution in your security stack should have a specific purpose and protect all the portions of your application, hence requiring a purpose-built solution for each. Without these protections, you’re leaving yourself vulnerable. In creating such a stack, a robust defense is created that covers a variety of attack vectors, such as preventing malicious access, managing automated threats, mitigating harmful behavior, and protecting sensitive data.
F5 Distributed Cloud brings all the tools into focus in a single interface, giving you the ability to secure your applications, including the most critical ones, efficiently and effectively. Here are a few quick points about what F5 offers to help provide the aforementioned: comprehensive security stack.
F5 Distributed Cloud WAAP (Web App and API Protection)
F5 addresses the WAF and API Protection under one title, but they are different solutions. Our F5 Distributed Cloud WAF has over 8,000 robust signatures that have been built up over the last 20 years. It is also incredibly easy to implement and opt-out-based to make that easy implementation even easier. Regarding the F5 Distributed Cloud API Protection portion, our API protection sits in line to perform both discovery and protection, in a single dashboard that provides per-endpoint rate limiting and protections alongside incredible visibility.
F5 Distributed Cloud Bot Defense
F5 addresses having a bot mitigation strategy through 4 different tiers of bot defense, one of which is included in the WAF that has over 8,000 robust signatures. The other tiers use a variety of signals, including environmental signals, behavioral signals, and network signals. The F5 Distributed Cloud Bot Defense aids in protecting your environment from automated threats that bots may cause. Protecting your application, and your customers’ information.
F5 Malicious User Detection and Mitigation
On the F5 platform, we can provide a machine-learning-based solution that generates a baseline of your traffic and based on a user identifier you specify, you’re able to see what a user comes outside of that baseline and maybe isn’t who they say they are.
F5 Distributed Cloud brings all these tools into focus in a single SaaS-driven Console, giving you the ability to secure your applications, including the most critical ones (yes even AI apps!), efficiently and effectively.
