Weblogic Persistence done right ;=)
Problem this snippet solves:
You want to use your Weblogic issued JSESSIONID session cookie to control persistence.
A sensible option would be to employ a Cookie Hash persistence profile but then you find it to be deficient in these respects:
- Mishandling of stale session cookies: A client making a request with a stale session cookie will cause the LTM to insert that stale session identifier into the persistence table.
- No support for cookie-less User-Agents whereby the session id is encoded in the URL.
- No tcl commands to query the cookie persistence table (e.g. for debug purposes).
As opposed to other Weblogic Persistence iRules found in Codeshare this irule will also allow for:
- Minimizing the number of persistence records by persisting on the JVMID alone. That means there will be as many records as there are Weblogic Application Server instances.
- Treating JSESSIONID value as opaque (i.e. no tolower thank you very much :)).
- Greater control of debug logging.
How to use this snippet:
If your Virtual Server services more than one application and/or pool, don't forget to employ a one-connect profile or attach an iRule that does
LB::detach in then response event (see SOL7964).It is assumed pool-selection is done in a LTM Policy otherwise, if done by iRule, take care of the order of iRule execution.
Code :
# Weblogic Persist iRule, Version 0.93
# Mars, 2012
# Last update: Aug, 2012
# Updated v11.6.0: 15/02/2015
# Created by Opher Shachar (contact me through devcentral.f5.com)
# Purpose:
# This iRule persists requests based on the JSESSIONID cookie issued by the
# Weblogic server. Since Weblogic appends its JVMID to the cookie, it affords
# us the chance to persist on just the JVMID minimizig the size of the
# persistence table.
# If not in a cookie the JSESSIONID will be searched for in the request uri.
when RULE_INIT {
# Set debug level to: 0, 1 or 2
set static::Weblogic_debug 1
# Persist on JVMID only (e.g., to minimize the persist-record table)
set static::Weblogic_JVMID 0
# Set the name and length of the Weblogic session cookie
set static::Weblogic_CookieName "JSESSIONID"
set static::Weblogic_PathName "jsessionid="
set static::Weblogic_PathLen [string length $static::Weblogic_PathName]
# Set a timeout of 12 hours (43,200 seconds)
set static::Weblogic_timeout 43200
when CLIENT_ACCEPTED {
set log_prefix "Client [IP::client_addr]:[TCP::client_port]"
# Log details for the request
if {$static::Weblogic_debug > 1} {
log local0. "$log_prefix: Request to [HTTP::uri] with cookie: [HTTP::cookie value $static::Weblogic_CookieName]"
# Check if there is a session cookie
set pkey [HTTP::cookie $static::Weblogic_CookieName]
if {$pkey eq ""} {
# Perhaps there's a jsessionid in the request uri. The jsessionid,
# when included is in the path: /path/to/file.ext;jsessionid=abcd!1234
set pkey [findstr [HTTP::path] $static::Weblogic_PathName $static::Weblogic_PathLen]
# Did we find a session id?
if {$pkey ne ""} {
# Extract the JVMID, if none then pkey is unchanged
set jvmid [findstr $pkey ! 1]
if {$static::Weblogic_JVMID and ($jvmid ne "")} { set pkey $jvmid }
# Persist off of the session id value with the set timeout
if {[persist lookup uie $pkey] ne ""} {
persist uie $pkey $static::Weblogic_timeout
log local0. "$log_prefix: Used persistence record from cookie or path: [persist lookup uie $pkey]"
# Client gave stale session id -- don't persist
persist none
if {$static::Weblogic_debug > 0} {
log local0. "$log_prefix: No persistence record found for key: $pkey"
# Client gave no session id -- don't persist
persist none
log local0. "$log_prefix: No session id given in cookie or path."
when HTTP_RESPONSE {
# Check if there is a session cookie in the response
if {$pkey eq "" and [HTTP::is_redirect]} {
# Perhaps there's a jsessionid in the redirect uri. The jsessionid,
set pkey [findstr [URI::basename "[HTTP::header Location]"] $static::Weblogic_PathName $static::Weblogic_PathLen]
if {$pkey ne ""} {
# Persist the session id value with the set timeout
persist add uie $pkey $static::Weblogic_timeout
set val [persist lookup uie $pkey]
log local0. "$log_prefix: Added persistence record from cookie or redirect: $pkey -> $val"
}Tested this on version:
11.4Updated Jun 05, 2023
Version 2.0Opher_Shachar_6
Joined January 12, 2012
