Set the SameSite Cookie Attribute for Web Application and BIG-IP Module Cookies
Problem this snippet solves:
UPDATE: Note that the work for SameSite is evolving rapidly and this new entry should be considered over the iRule contents below.
Chrome (and likely other browsers to follow) will enforce the SameSite attribute on HTTP cookies to Lax beginning soon (initial limited rollout week of Feb 17th, 2020) which could impact sites that don't explicitly set the attribute. This iRule will set the SameSite attribute in all BIG-IP and app cookies found in Set-Cookie headers. Note that this would not modify cookies set on the client using javascript or other methods.
Contributed by: hoolio
How to use this snippet:
Apply the iRule to the appropriate virtual servers.
Code :
when HTTP_RESPONSE_RELEASE { # Set all BIG-IP and app cookies found in Set-Cookie headers using this iRule to: # none: Cookies will be sent in both first-party context and cross-origin requests; # however, the value must be explicitly set to None and all browser requests must # follow the HTTPS protocol and include the Secure attribute which requires an encrypted # connection. Cookies that don't adhere to that requirement will be rejected. # Both attributes are required together. If just None is specified without Secure or # if the HTTPS protocol is not used, the third-party cookie will be rejected. # # lax: Cookies will be sent automatically only in a first-party context and with HTTP GET requests. # SameSite cookies will be withheld on cross-site sub-requests, such as calls to load images or iframes, # but will be sent when a user navigates to the URL from an external site, e.g., by following a link. # # strict: browser never sends cookies in requests to third party domains # # Above definitions from: https://docs.microsoft.com/en-us/microsoftteams/platform/resources/samesite-cookie-update # # Note: this iRule would not modify cookies set on the client using Javascript or other methods outside of Set-Cookie headers! set samesite_security "none" # Log debug to /var/log/ltm? (1=yes, 0=no) set cookie_debug 1 set cookie_names [HTTP::cookie names] if {$cookie_debug}{log local0. "[IP::client_addr]:[TCP::client_port]: \[HTTP::header values {Set-Cookie}\]: [HTTP::header values {Set-Cookie}]"} if {$cookie_debug}{log local0. "[IP::client_addr]:[TCP::client_port]: \$cookie_names ([llength $cookie_names]): $cookie_names"} foreach a_cookie $cookie_names { # Remove any prior instances of SameSite attributes HTTP::cookie attribute $a_cookie remove {samesite} # Insert a new SameSite attribute HTTP::cookie attribute $a_cookie insert {samesite} $samesite_security # If samesite attribute is set to None, then the Secure flag must be set for browsers to accept the cookie if {[string equal -nocase $samesite_security "none"]} { HTTP::cookie secure $a_cookie enable } } if {$cookie_debug}{log local0. "[IP::client_addr]:[TCP::client_port]: Set-Cookie header values: [HTTP::header values {Set-Cookie}]"} }
Tested this on version:
13.0Published Feb 06, 2020
