Office 365 Data Group builder using F5 Python SDK
Problem this snippet solves:
Python script which pulls O365 URL's/IP's from microsoft published XML formatted list, parses into python dictionaries formatted for F5 data group, and uses F5 Python SDK to create or update data groups on BIG-IP for each MS product. The script will check if the data group already exists, and if so update based on changes. Once the data groups are installed they can used/referenced by any F5 feature/configuration that can reference a data group.
How to use this snippet:
Python version: 3.6
Python Modules Required: * f5-sdk * requests * f5-icontrol-rest * xmltodict
Update script variables for your environment: BIGIP_ADDRESS = ' ' BIGIP_USER = ' ' BIGIP_PASS = ' '
to execute: python3 o365_dg_builder.py
Code :
import requests
import xmltodict
from collections import OrderedDict
from f5.bigip import ManagementRoot
from icontrol.exceptions import iControlUnexpectedHTTPError
import argparse
MS_URL = 'https://support.content.office.net/en-us/static/O365IPAddresses.xml'
BIGIP_ADDRESS = '192.168.15.165'
BIGIP_USER = 'admin'
BIGIP_PASS = 'admin'
def load_bigip(f5_host, f5_user, f5_pass):
bigip = ManagementRoot(f5_host, f5_user, f5_pass)
return bigip
def get_o365_data():
o365data = requests.get(MS_URL)
records = []
pdata = xmltodict.parse(o365data.content)
for product in pdata['products']['product']:
prod_name = product['@name']
if isinstance(product['addresslist'],list):
for addrlist in product['addresslist']:
record = {}
if 'address' in addrlist.keys():
record['name'] = "{}_{}_{}".format('MS',prod_name, addrlist['@type'])
if '@type' in addrlist.keys():
if addrlist['@type'] == 'URL':
record['type'] = 'string'
elif (addrlist['@type'] == 'IPv4' or addrlist['@type'] == 'IPv6'):
record['type'] = 'ip'
# MS XML has duplicate entries, unify the list before adding to record
new_addr_l = list(set(addrlist['address']))
record['records'] = new_addr_l
records.append(record)
if isinstance(product['addresslist'],OrderedDict):
if len(product['addresslist']['address']) > 0:
record = {}
record['name'] = "{}_{}_{}".format('MS', prod_name, product['addresslist']['@type'])
if product['addresslist']['@type'] == 'URL':
elif product['addresslist']['@type'] == 'IPv4' or product['addresslist']['@type'] == 'IPv6':
record['records'] = list(set(product['addresslist']['address']))
return records
def compare_dg_entries(record, old_dg_l):
# let's get the values to compare, and see what updates we need to make
#compare lists
addrs_to_rem = [x for x in old_dg_l if x not in record]
addrs_to_add = [x for x in record if x not in old_dg_l]
return addrs_to_rem, addrs_to_add
def create_dg(bigip, record):
if not bigip.tm.ltm.data_group.internals.internal.exists(name=record['name']):
bigip.tm.ltm.data_group.internals.internal.create(**record)
create_status = 'SUCCESS'
else:
old_dg_entries = bigip.tm.ltm.data_group.internals.internal.load(name=record['name'])
# pull into a list
old_dg_l = []
for entry in old_dg_entries.records:
old_dg_l.append(entry['name'])
addrs_to_rem, addrs_to_add = compare_dg_entries(record['records'], old_dg_l)
if len(addrs_to_add)==0 and len(addrs_to_rem)==0:
create_status = 'SKIPPED'
else:
if len(addrs_to_rem) > 0:
for addr in addrs_to_rem:
old_dg_entries.records.remove(next(x for x in old_dg_entries.records if x['name'] == addr))
if len(addrs_to_add) > 0:
for addr in addrs_to_add:
old_dg_entries.records.append({'name':addr})
old_dg_entries.update()
# if you get time create log of updated entries
create_status = 'UPDATED'
return create_status
try:
bigip = load_bigip(BIGIP_ADDRESS, BIGIP_USER, BIGIP_PASS)
except iControlUnexpectedHTTPError as e:
print(e)
exit(1)
if bigip:
records = get_o365_data()
for record in records:
try:
status = create_dg(bigip, record)
print("BIGIP: {}, Data Group: {}, Create Status {}".format(BIGIP_ADDRESS, record['name'], status))
status = 'FAILED'
print("BIGIP: {}, Data Group: {}, Create Status {}, Error {}".format(BIGIP_ADDRESS, record['name'], status, e))Tested this on version:
13.01 Comment
- NUT2889
Right now Microsoft change to use JSON format instead via https://endpoints.office.com/endpoints/worldwide?clientrequestid=b10c5ed1-bad1-445f-b386-b919946339a7
The parser in python script might not working with JSON format right?
