MS Exchange Active Sync Multi Device Auth
Problem this snippet solves:
Utilizes the Exchange extended attributes to store multiple devices per client, (i.e. iPhone, iPad, etc.) to validate the device as approved for the assigned user.
Code :
# Apply DeviceID restriction to all ActiveSync directory traffic
if {[HTTP::path] == "/Microsoft-Server-ActiveSync"} {
# Capture DeviceID attributes stored in user mailbox settings Custom Attribute1 - Custom Attribute3 Managed via EMC
set mblDeviceID1 [string toupper [ACCESS::session data get "session.user.deviceid1"]]
set mblDeviceID2 [string toupper [ACCESS::session data get "session.user.deviceid2"]]
set mblDeviceID3 [string toupper [ACCESS::session data get "session.user.deviceid3"]]
# Determine whether connection is Base64 encoded, (Windows Phone) and if necessary begin decoding process
set string_b64encoded [HTTP::query]
if {[catch {b64decode $string_b64encoded} string_b64decoded] == 0 and $string_b64decoded ne ""} {
binary scan $string_b64decoded x4H2 IDlenHEX
scan $IDlenHEX %x IDlenDEC
set IDlen [expr "$IDlenDEC * 2"]
binary scan $string_b64decoded x5H$IDlen HEXdeviceID
set string_sentid [string toupper $HEXdeviceID]
set string_sentid [string toupper [URI::query [HTTP::uri]]]
# compare deviceID presented in HTTP::query with stored deviceID attribute
if {$string_sentid contains $mblDeviceID1} {
log local0.info "Successful login with deviceID: $string_sentid"
} elseif {$string_sentid contains $mblDeviceID2} {
} elseif {$string_sentid contains $mblDeviceID3} {
log local0.info "Failed login with deviceID: $string_sentid"
ACCESS::session remove
}Published Mar 18, 2015
Version 1.0CodeCentral_194
Joined May 04, 2019
