Extracting_info_from_bigip_conf
Problem this snippet solves:
A simple perl script that allows you to locate a block contain an element withing bigip.conf
How to use this snippet:
cut and paste this code to a file (eg. /tmp/mygrep.pl) and make sure the executable bit is set (eg. chmod a+x /tmp/mygrep.pl)
Code :
# Script Source
#!/usr/bin/perl
use strict;
my ($File, $Pattern) = @ARGV;
my $buf;
open (fh, $File) || die "Cant open $File";
local $/;
$buf=;
close (fh);
while ($buf =~ /([^\n]*\{[^\{]*$Pattern[^\}]*\})/sg){
print "$1\n---\n";
# SAMPLE
[root@bigip:Active] config # /tmp/mygrep.pl /config/bigip.conf http-xff
virtual vip1.80 {
pool vip1.80
destination aaa.bbb.ccc.ddd:http
ip protocol tcp
rules SNAT2VIP
profiles
http-xff
tcp-lan-optimized
serverside
tcp-wan-optimized
clientside
persist source_addr_30min
virtual vip-2.80 {
pool vip-2.80
destination mmm.nnn.ooo.ppp:http
ip protocol tcp
rules SNAT2VIP
profiles
http-xff
tcp-lan-optimized
serverside
tcp-wan-optimized
clientside
[root@bigip:Active] config # /tmp/mygrep.pl /config/bigip.conf password
$ ./test.pl h password
user root {
password crypt "[cut]"
user admin {
description "Admin User"
group [cut]
home "[cut]"
shell "[cut]"
role administrator in all
user f5emsvr {
description "F5 EM Service Account"
id [cut]
group [cut]
home "[cut]"
shell "[cut]"
role guest in all
configsync {
# NOTE: It's not well tested, use it on your own risk and on dev machine first. Published Mar 17, 2015
Version 1.0hwidjaja_37598
Altostratus
Joined June 02, 2008
