Especial Load Balancing Active-Passive Scenario (I)
Problem this snippet solves:
This code was written to solve this issue
REF - https://devcentral.f5.com/s/feed/0D51T00006i7jWpSAI
Specification:
- 2 clusters with 2 nodes each one.
- each cluster will be served as active-passive method.
- each node in the cluster will be served as round robin.
- when a cluster changes to active, it will keep this status although the initial active cluster change back to up status.
- Only one BIG-IP device.
There are many topics suggesting to use "Manual Resume" trying to goal this specifications, but this requires to manually restore each node when is back online. My initial idea was to have an unattended virtual server.
To do so, I use a combination of persistence and an internal virtual server loadbalancing (Vip-targeting-Vip in the same device).
How to use this snippet:
This scenario is composed by the next set of objects:
- 4 nodes (Node1, Node2, Node3, Node4)
- 1 additional node called "internal_node" (which represents the VIP used on VIP-Targeting-VIP)
- 2 pools called "ClusterA_pool" and "ClusterB_pool" (which points to each pair of nodes)
- 1 additional pool called "MyPool" (which points the two internal VIP)
- 2 virtual servers called "ClusterA_vs" and "ClusterB_vs" (which use RoundRobin to the pools of the same name)
- 1 virtual server called "MyVS" (which is the visible VS and points to "MyPool")
By the way, I use a "Slow Ramp Time" of 0 to reduce the failover time.
Following you can find an example of configuration:
ltm virtual MyVS {
destination 10.130.40.150:http
ip-protocol tcp
mask 255.255.255.255
persist {
universal {
default yes
pool MyPool
profiles {
tcp { }
rules {
MyRule
source 0.0.0.0/0
translate-address enabled
translate-port enabled
vs-index 53
ltm virtual ClusterA_vs {
destination 10.130.40.150:1001
ip-protocol tcp
pool ClusterA_pool
profiles {
tcp { }
source 0.0.0.0/0
vs-index 54
ltm virtual ClusterB_vs {
destination 10.130.40.150:1002
ip-protocol tcp
pool ClusterB_pool
profiles {
tcp { }
source 0.0.0.0/0
vs-index 55
ltm pool ClusterA_pool {
members {
Node1:http {
address 10.130.40.201
session monitor-enabled
state up
Node2:http {
address 10.130.40.202
state up
monitor tcp
slow-ramp-time 0
ltm pool ClusterB_pool {
members {
Node3:http {
address 10.130.40.203
state up
Node4:http {
address 10.130.40.204
state up
monitor tcp
slow-ramp-time 0
ltm node local_node {
address 10.130.40.150
Code :
when CLIENT_ACCEPTED {
set initial 0
set entry ""
when LB_SELECTED {
incr initial
# Checks if persistence entry exists
catch { set entry [persist lookup uie [virtual name]] }
# Loadbalancing selection base on persistence
if { $entry eq "" } {
set selection [LB::server port]
set selection [lindex [split $entry " "] 2]
set status [LB::status pool MyPool member [LB::server addr] $selection]
if { $status ne "up" } {
catch { [persist delete uie [virtual name]] }
# Adds a new persistence entry
catch { persist add uie [virtual name] }
# Applies the selection
switch $selection {
# This numbers represents the ports used at the VIP-targeting-VIP
"1001" {
LB::reselect virtual ClusterA_vs
"1002" {
LB::reselect virtual ClusterB_vs
}Tested this on version:
12.11 Comment
- mrdragosh
Cirrus
Hello,
Does this article not apply to this scenario?
K10379: A local virtual server IP address cannot be used as a pool member
L.E. Solved via
switch $selection { # This numbers represents the ports used at the VIP-targeting-VIP "1001" { LB::reselect virtual ClusterA_vs } "1002" { LB::reselect virtual ClusterB_vs } }?
