Giammarco's avatar
Giammarco
8 years ago
Zonerunner Issue
Hi guys,
i'm trying to solve two big issue using my F5 as master DNS.
First: i want to forward a full PTR network (in my case a /16) to another BIND but it doesn't seems to work. PTR are resolved only if F5 is the master. Is a supported feature or not? If I configure same forward on a normal BIND it works
Second: i'm forwarding an *.local domain to my AD servers but i've found that every time I do a dig using F5 VIP it reports back also authority section and this create issue using particular services
here is an example:
dig @ AD server output:
; <<>> DiG 9.9.4-RedHat-9.9.4-51.el7_4.2 <<>> @10.10.10.200 test.local
; (1 server found)
;; global options: +cmd
;; Got answer:
;; ->>HEADER<<- opcode: QUERY, status: NOERROR, id: 44844
;; flags: qr aa rd ra; QUERY: 1, ANSWER: 7, AUTHORITY: 0, ADDITIONAL: 1
;; OPT PSEUDOSECTION:
; EDNS: version: 0, flags:; udp: 4000
;; QUESTION SECTION:
;test.local.                    IN      A
;; ANSWER SECTION:
test.local.             600     IN      A       10.x.x.x
test.local.             600     IN      A       192.168.x.x
dig @ F5 (that forwards to AD server):
; <<>> DiG 9.9.4-RedHat-9.9.4-51.el7_4.2 <<>> @10.10.10.201 test.local
; (1 server found)
;; Got answer:
;; ->>HEADER<<- opcode: QUERY, status: NOERROR, id: 44763
;; flags: qr rd ra; QUERY: 1, ANSWER: 7, AUTHORITY: 13, ADDITIONAL: 1
; EDNS: version: 0, flags:; udp: 4096
;test.local.                    IN      A
;; ANSWER SECTION:
;; AUTHORITY SECTION:
.                       71938   IN      NS      f.root-servers.net.
.                       71938   IN      NS      c.root-servers.net.
.                       71938   IN      NS      a.root-servers.net.
.                       71938   IN      NS      b.root-servers.net.
.                       71938   IN      NS      d.root-servers.net.
.                       71938   IN      NS      g.root-servers.net.
.                       71938   IN      NS      e.root-servers.net.
.                       71938   IN      NS      h.root-servers.net.
.                       71938   IN      NS      l.root-servers.net.
.                       71938   IN      NS      m.root-servers.net.
.                       71938   IN      NS      i.root-servers.net.
.                       71938   IN      NS      k.root-servers.net.
.                       71938   IN      NS      j.root-servers.net.
My F5 are running LTMOS 11.6.1 HF1 Any help is very appreciated!
  • JG's avatar
    JG
    It is hard to answer your questions without knowing the specific configurations of your DNS server. And:
    • Do you allow recursion?
    • Have you configured a forwarder?
    • What are your dig commands?
  • Hi,
    yes, this is the named configuration on the F5
    restrict rndc access to local machines
    use the key in the default place: /config/rndc.key
    controls {
        inet 127.0.0.1 port 953 allow {
            127.0.0.1;
    logging {
        channel logfile {
            syslog daemon;
            severity error;
            print-category yes;
            print-severity yes;
            print-time yes;
        category default {
            logfile;
        category config {
            logfile;
        category notify {
            logfile;
    options {
        listen-on port 53 {
            127.0.0.1;
            "zrd-acl-000-001";
            "zrd-acl-000-002";
            "zrd-acl-000-000";
        listen-on-v6 port 53 {
            ::1;
        recursion yes;
        directory "/config/namedb";
        allow-transfer {
            localhost;
        allow-recursion {
            lan_hosts;
        check-names master warn;
        check-integrity yes;
        max-journal-size 1M;
        forwarders {
            8.8.8.8;
            8.8.4.4;
    acl "zrd-acl-000-000" {
        127.10.0.0;
    acl "zrd-acl-000-002" {
        127.10.0.2;
    acl "lan_hosts" {
        10.10.10.0/24;
    acl "zrd-acl-000-001" {
        127.10.0.1;
    acl "extkey" {
        key "external";
    acl "noextkey" {
        !key "external";
    key "external" {
        algorithm hmac-md5;
        secret "";
    the dig command that I'm doing is a simple:
    dig @IP(AD or F5) SRV test.local
