Wrong host IP show in top left corner in GUI
I have upgrade f5 BIG IP 1600 from 10.2.3 to 11.6.1 in standby node after that i found IP address is "127.0.0.1" instead of 10.50.25.78 in top left corner in GUI.
Hostname:CR08CHLB02.proxy.com IP Address:127.0.0.1
[root@CR08CHLB02:Standby:Standalone] config cat /etc/hosts
THIS IS AN AUTO-GENERATED FILE - DO NOT EDIT!!! Use the tmsh shell utility to make changes to the system configuration. For more information, see tmsh -a help sys global-settings.
127.0.0.1 localhost.localdomain localhost CR08CHLB02.proxy.com 127.2.0.1 sccp aom AOM 127.2.0.2 CR08CHLB02.proxy.com 127.1.1.2 tmm 127.1.1.3 tmm1 10.8.4.55 CR08CHLB02.proxy.com 192.168.0.1 peer [root@CR08CHLB02:Standby:Standalone] config
Please assist me how to change this IP address "127.0.0.1" to 10.50.25.78
BR
- nathe
Cirrocumulus
Have you checked what's configured in the Management Port section of the GUI? System - Platform.
