Carlos_Hernand7
Sep 28, 2011WMI Monitor issue
Hello all,
Recently I have configured the WMI monitor & Data Gathering Agent in Windows 2008 + IIS 7. Everything worked like a charm.
I am trying to do the same with a Windows 2003 + IIS 6 and I haven't been able to make it work. I followed all the steps in the Configuration Guide but it did not work at all. The node is marked down as soon as the monitor is assigned to it.
I enabled the logging for WMI performance monitor using this article:
http://support.f5.com/kb/en-us/solutions/public/4000/600/sol4690.html
And when I checked the log the only thing I can see is:
"Target: http://XXX.XXX.XXX.XXX:80/scripts/F5Isapi.dll?GetCPUInfo (ID/Pwd: [email protected]/Mypassw0rd)
Failure processing HTTP request"
We are using LTM ver 10.2.0 on a 6400 D63 hardware.
¿Any ideas on how to troubleshoot this issue?
Thanks a lot for your assistance.
Carlos
- The_Bhattman
Hi Carlos,
Did you take a look at the following article
http://support.f5.com/kb/en-us/solutions/public/4000/400/sol4454.html?sr=16814058
I hope this helps
Bhattman - Carlos_Hernand7
Hi Bhattman,
First of all thanks for your response.
Yes, I did look at it but it doesn't apply to my case. I am trying to configure the F5IsHandler.dll in an IIS6, not the f5isapi.dll.
I understand installing both of them is not necessary, isn't?
Even though, I already followed those steps and tried to install the f5isapi.dll instead the F5IsHandler.dll and it did not work either.
Thank you.
