bhorta1_9687's avatar
bhorta1_9687
Nov 04, 2011
Will this irule work okay to "Patch" a messed up web application
I am running version 10.2 and unfortunately there is a little problem with a "Cloud" Application that consists of several front end web servers that talk to a few db servers in the back.Every so often some kind of bad data hits the front end customer facing web servers returning a nasty confusing 500 error that looks like a BSOD message on steroids.
(If a user retries a few times they will get the output that is supposed to be correct)
So I thought maybe the F5 could save the day using it like a virtual software patch for now and hide the "500 error" from the end users
Anytime a pool member returns an error 500 just select the next pool member in line and see if it is okay. If it is, then just spit out the correct website.
And let the programmers work in peace while they fix the issue.
when CLIENT_ACCEPTED {
set variable def_pool to pool name queried by the LB command.
set the variable retries to zero
set def_pool [LB::server pool]
set retries 0
set request_headers [HTTP::request]
when LB_SELECTED {
if { $retries >= 1 } {
LB::mode rr
LB::reselect pool $def_pool
when HTTP_RESPONSE {
if { [HTTP::status] starts_with "5" } {
incr retries
log local0. "5xx error caught: retry $retries out of [active_members [LB::server pool]]"
if { $retries < [active_members $def_pool] } {
HTTP::retry $request_headers
The command LB::reselect pool will advance the pointer down to the next available load balancer
LB::mode rr
LB::mode reselect
using mode rr to force into roundrobin mode because its set to least connections, hop to next server in line.
  • this is mine.
    [root@iris:Active] config  b virtual bar list
    virtual bar {
       snat automap
       pool foo
       destination 172.28.17.33:http
       ip protocol tcp
       rules myrule
       profiles {
          http {}
          tcp {}
    [root@iris:Active] config  b pool foo list
    pool foo {
       members {
          74.125.235.48:http {}
          172.28.17.22:http {}
    [root@iris:Active] config  b rule myrule list
    rule myrule {
            set retries 0
            log local0. "$request_headers"
    when LB_SELECTED {
            log local0. "[LB::server addr]"
            log local0. "[IP::server_addr]:[TCP::server_port] [HTTP::status]"
            if {[HTTP::status] starts_with "5"} {
                    incr retries
    [root@iris:Active] config  curl -I http://172.28.17.22
    HTTP/1.0 500 Internal Server Error
    Server: BigIP
    Connection: Keep-Alive
    Content-Length: 0
    [root@iris:Active] config  curl -I http://172.28.17.33
    HTTP/1.1 200 OK
    Date: Sat, 05 Nov 2011 01:32:05 GMT
    Expires: -1
    Cache-Control: private, max-age=0
    Content-Type: text/html; charset=ISO-8859-1
    Server: gws
    X-XSS-Protection: 1; mode=block
    X-Frame-Options: SAMEORIGIN
    Transfer-Encoding: chunked
    [root@iris:Active] config  tail -f /var/log/ltm
    Nov  5 09:29:22 local/tmm info tmm[1609]: Rule myrule : HEAD / HTTP/1.1  User-Agent: curl/7.15.5 (i686-redhat-linux-gnu) libcurl/7.15.5 OpenSSL/0.9.8b zlib/1.2.3 libidn/0.6.5  Host: 172.28.17.33  Accept: */*
    Nov  5 09:29:22 local/tmm info tmm[1609]: Rule myrule : 172.28.17.22
    Nov  5 09:29:22 local/tmm info tmm[1609]: Rule myrule : 172.28.17.22:80 500
    Nov  5 09:29:22 local/tmm info tmm[1609]: Rule myrule : 5xx error caught: retry 1 out of 2
    Nov  5 09:29:22 local/tmm info tmm[1609]: Rule myrule : 74.125.235.48
    Nov  5 09:29:22 local/tmm info tmm[1609]: Rule myrule : 74.125.235.48:80 200
