Robert_47833's avatar
Robert_47833
Jul 20, 2011
will rand() cause performance issue
rand()
one question about rand
will rand cause performance issue?How to test it?
Can u give me an example
We want to put rand() in production
  • Hi,Ryan
    skewing is because I can't reset 3561 to 0 in the rule with rand()
    I can only set it to
    +-> HTTP_REQUEST 3563 total 0 fail 0 abort
    | | Cycles (min, avg, max) = (0, 0, 0)
    +-> HTTP_RESPONSE 168 total 0 fail 0 abort
    and get
    | | Cycles (min, avg, max) = (0, 466582, 1446128)
    1:the reason I can't use default profile is besides this pool,under this VS ,there are 10 other pools which don't need persist
    so I can only achieve this via irule,this VS dones't have default pool,only irule
    1:I don't know how to optimize rand()
    2:I don't know how to insert cookie and persist it in irule
    pls help me
  • under this VS,there are another 10 pools,so if I use Default Persistence Profile" "cookie"... ,it will affect other pools.
  • Follow Forum post http://devcentral.f5.com/Community/GroupDetails/tabid/1082223/asg/50/aft/1180627/showtab/groupforums/Default.aspx. It's the same topic.
    Thanks,
    Bhattman
